IMO you have 3 possible solutions
1.) Have your guitar body re-routed
2.) Follow my idea on how to mod an original edge trem to fit any Ibanez.
3.) Buy a different compatible trem that you might not like.
Here's what I did with my RG350 and the Edge III. Buy an original
Ibanez Edge trem from the Bay, then find someone with a grinder. Remove and unscrew the fine tuning pegs from the unit and grind them down to shorten their length. You must supply a new tapper to them so they can go back into the unit. Do Not flatten them, or they will not go back in right. The end of the peg where the
Allen wrench goes to tighten or lock the string down should now fall under the "arm rest" of the trem where it says licensed under Floyd Rose. This will provide plenty of clearence for the routing on the guitar. Then, have someone grind the front edges of the trem where the knife edges reside, and on the backside of the base to allow clearence. If you don't mind a little cosmetic alterations, then this is a good mod that's easy to do. Also, if you can find someone to re-chrome the trem it will look like a stock piece. I'm planning on having it done by the end of the summer.Problem fixed!
I'll post pictures of mine when I get back to my house from this weekend of vacationing.[/quote]
