Tech: Setup, Repairs and Mods
Replacing Edge/LoPro Edge with a ZR tremolo?
05-27-2009, 04:37 PM
ZOMB13
Posts: 779 - iTrader: (
I just won a ZR tremolo ($50) and I decided to replace my lo pro edge on my RG550-560.
I know some modifications are needed
- Bigger trem post hole
- Routing for ZPS
has anyone attempted this or have any tips?
ZOMB13
Visit ZOMB13's homepage!
Find all posts by ZOMB13
05-27-2009, 06:18 PM
GuitarBizarre
Posts: 1,182 - iTrader: (
Re: Replacing Edge/LoPro Edge with a ZR tremolo?
My advice is to get an S to take measurements from. The ZR system isn't the easiest to install, even compared to standard floyds.
GuitarBizarre
Find all posts by GuitarBizarre
05-27-2009, 09:23 PM
ZOMB13
GuitarBizarre
I working on getting the specs on the cavities.
ZOMB13
05-31-2009, 10:58 AM
TMatt142
Posts: 543 - iTrader: (
I'm wondering why you would want to replace THE #1 trem with THE #2 trem available....? Don't get me wrong, I like ZR's ...at least the newer ones but I wouldn't get rid of an edge pro/lo-pro for one. Especially if you're replacing a lo-pro.....
TMatt142
Find all posts by TMatt142
05-31-2009, 06:29 PM
ZOMB13
TMatt142
I like the lo pro, I do, but I want a ZR as it felt better to me.
I have another guitar with a lo pro and a edge anyway.
ZOMB13
05-31-2009, 07:04 PM
GuitarBizarre
TMatt142
Thats only your preference. There are guys out there who have differing opinions on the issue, believe it or not. Personally, the ZR is my absolute favourite trem, including the original edge (And I own both. The ZR returns to better pitch even without the ZPS, incidentally)
If I were to spec out my ideal trem system from top to bottom it would be essentially a ZR with modifications. THey have a lot going for them, and unless you've spent time with all the various trems, I'd be very hesitant to start making claims like '#1 trem'
Now playing on Winamp:
Roots Manuva - Join The Dots
via
FoxyTunes
GuitarBizarre
05-31-2009, 07:20 PM
Hub
Posts: 282 - iTrader: (
+1
I've been trying to destroy a ZR trem for more than 2.5 years now, never had to do a thing to it. Only tune when changing strings, never touch the fine tuners in between!
Hub
Find all posts by Hub
06-01-2009, 05:04 AM
nsabino
Posts: 463 - iTrader: (
Sabu2k1
Hi, do you wanna sell the lo-pro edge? What color is it? It's the original low-pro edge that you´re referring to, right?
P.M me or e-mail me if you're interested:
nsabino@uac.pt
Regards,
Nelson
nsabino
Find all posts by nsabino
06-04-2009, 01:00 PM
albee1952
Posts: 784 - iTrader: (
installing the ZR in place of any Edge is going to be a lot of work. Once you start routing, there will be no going back. You also will need to dowel the stud holes and drill new ones as the stud spacing is not the same. The best way to approach will be(as said) to get an S type with the ZR installed(or an empty body) so you can measure and create routing templates. I started all that and just decided it was too much(although I would love to try a ZR on an RG). If you do go ahead with this, move slow, and be careful.
albee1952
Find all posts by albee1952
zr tremolo conversion
how to measure tremolo to scale
what metal is edge 3 tremolo made out of
how to setup an edge 3 tremolo
is the edge zero tremolo a good tremolo
Can you replace an edge trem with a LoPro Edge? - Is it poss
Cycovision
01:22 AM
replacing an edg/lopro trem with the edge pro
abstrakt
10:50 AM
Is the LoPro Edge easily swappable with the Edge?
agquake
02:10 PM
Feel of LoPro Edge 7 vs LoPro Edge 6 and other setup issues
mdrobnak_rg7
03:56 PM
Edge LoPro Tremolo rust
AlexBHome
03:31 AM
06:28 AM
