Old 03-18-2004, 11:24 PM
pedalinbob  is offline
Posts: 88  -  iTrader: (1)
RG fret buzz issue
i have an RG470 that is only around 1 year old.
i used the guide here on jemsite to set it up properly, because i noticed that it has a moderate amount of buzziness in the lower register.
this can be diminished (but not eliminated) if i raise the bridge a lot...but, i went by the tuning guide and set it so that buzzing was non-existent from the 10th-24th fret. playability feels much better this way.
most of the buzzing is from the low E string, 2nd fret through 9th fret.
(i use .009s tuned flat)
i checked neck relief, and it appears to be very close, but i decided prehaps i could add some more relief. when loosening the truss rod, it only turned about 1/8th turn, when it became completely loose.
in other words, i cannot loosen it any further.
the guitar has never been abused or exposed to extreme temps...heck, i havent even played it much.
from here i dont believe i have the expertise to rectify the problem--advice?
thanks,
Bob
Old 03-19-2004, 11:52 AM
uh-oh...no replies.
i wonder if my guitar is screwed.
know any good guitar techs in the southeast michigan area?
if not, maybe i can send it to ibanez for diagnosis.
Bob&lt;---frustrated.
Old 03-19-2004, 12:17 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
sorry for no replies, Bob, that's a pretty tricky issue, actually. you're right anyway, that's job for professionals.
good luck
Old 03-20-2004, 09:17 PM
The Madness Here  is offline
Posts: 249  -  iTrader: (0)
what i would try first is either tuning your guitar to standard, or if you must downtune, use thicker strings. It could be that the strings are just vibrating in a very large ellipse. Tighter strings (from a higher tuning or thicker strings) will make some of that go away.
Old 04-05-2004, 04:55 PM
gn86  is offline
Posts: 18  -  iTrader: (0)
I also have some similair problems.. meh.. I just think the hole thing sucks balls! I only like my ibanez because of the feel, the thin neck and the light basswood body, otherwise, it sucks balls..
Old 04-06-2004, 03:19 AM
bachle7  is offline
Posts: 306  -  iTrader: (0)
Did you look down the neck to see if it is warped? If you have really low action, you will likely always have a little fret buzz.
This site may help.
http://www.frets.com/FRETSPages/Luth.../buzzlist.html
basswood body, fret buzz, guitar tech, neck relief, truss rod
