RG2570E Paintjob Help!!! - Jemsite
Old 12-20-2016, 04:46 PM
ChokeShot GG  is offline
Posts: 6  -  iTrader: (0)
Hey ther guys!
So i had an RG2570E for a while now so i decided to paint it because i have corrosive sweat and it would make the guitar body slowly turn yellow , so i took it upon me to have a little project with my favourite guitar!After carefully sanding down the guitar body i proceeded to paint the guitar , the result came out amazing! i gave it a bit of a swirly vibe to it,after i was done and i was admiring my work , i would have used varnish and later on i'd pass it with a high gloss to have that glowing finish ,but soon a small disaster came so my project came to a pause...i applied the varnish ,and after lettting it set for a bit , it just came off like , the half of the guitar just peeled off and now 1/4 of my guitar has varnish on it , and the rest is the solid colour,is there a chance to remove it? or what do you suggest i should do??,i'll leave some pictures of the guitar right now attached to the post so you can see it
Thanks for your help!
Old 12-20-2016, 08:11 PM
guilherme87  is offline
Posts: 27  -  iTrader: (0)
Re: RG2570E Paintjob Help!!!
It sounds like the varnish had a negative reaction to the paint you used. I can only see one picture in the thread so im not sure what the damage is like....however you may need to sand everything down and repaint it and either use a different product for the clear coat or bring it to somebody else for the clear coat.
Old 12-20-2016, 08:27 PM
So there is no way for me to remove the varnish? Nothing else? Just remove it?
Old 12-21-2016, 01:48 PM
Bump,still strugling to figure out what to do!
Old 12-22-2016, 02:49 AM
Rodzo  is offline
Posts: 350  -  iTrader: (0)
I'm only seeing the one pic and not clear as to what happened. When you say it pealed off, you mean the varnish and your paint job, revealing only the factory finish?
Sounds like a prep problem...
1. What grit did you sand the original paint down to?
2. What type of paint did you use for your graphic?
Lets start there...
Old 12-22-2016, 04:46 AM
I think the paint was acrylic and the varnish wasn't so what i was thinking was could i sand it down with ultra fine grit sandpaper and remove the varnish without ruining the paint.. I'll try that today... Thanks for your help! I'll update the post later today, what do you think about the paint though
Old 12-22-2016, 06:11 AM
peromucho7  is offline
Posts: 377  -  iTrader: (0)
First few layers should be just mist!
Then leave to dry between every layer .
When you build enough thick layer of varnish, then you can spray harder.
If you need to test varnish, test it into spring cavity to see reaction.
Old 12-22-2016, 10:17 AM
Rodzo  is offline
If your paint is coming off - then the problem is with your surface prep of the guitar. It doesn't have a good surface to adhere to.
ibanez rg , rg 2570e
Help with JEM 555 paintjob Resurrection Tech: Setup, Repairs and Mods 3 02-01-2011 01:01 PM
Desert Yellow Paintjob? MrChong Tech: Setup, Repairs and Mods 2 01-11-2011 11:16 AM
Cool Paintjob? Hutch34 JEM and Universe Guitars 33 02-18-2007 01:23 AM
My new JS1 with a new paintjob rikkbeatty JS (Satriani Model) Ibanez Guitars 79 02-09-2007 05:06 PM
My strat - time for a new paintjob Scoff X Other 6-string Guitars (non-Ibanez brand) 5 04-26-2001 08:11 PM
Powered by
