Old 06-24-2005, 12:27 PM
Obfuscolios  is offline
Posts: 56  -  iTrader: (0)
Unhappy
RG3120 Neck problems
Just moved to Orlando from Houston, and the neck on my trusty 2001 RG3120 has decided to go whacko, meaning buzz that never existed has suddenly appeared, from the climate change even though the weather here doesn't really feel much different than the humidity in Houston. Anyway, I've taken the guitar to two separate techs (Guitar Factory and a highly recommended repair guy from... gasp... Guitar Center) to no avail. I still get massive fret buzz on the low E and A, particularly in the 7 to 12 fret range. We've raised/lowered the action and adjusted the truss, but the buzz is still there. Also, both of the techs said that the neck wasn't warped and the frets were level, but the buzz is still there. Any suggestions?? Could it be that I need a neck shim? Analyze the nut to take out the shim, if there is one there? Help!!!
Mike
Old 06-25-2005, 02:32 AM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Re: RG3120 Neck problems
Since you're in Orlando and this is the annual Jemfest weekend, hop on over to the Radisson Resort Worldgate with your 3120 and you'll find more Ibanez afficianados than you can shake a stick at. Look for Rich and if your lucky, he'll have a look at it for you.
fret buzz, neck shim
FS RG550 body & neck, RG570 neck & misc screamndemon69 Classified Ads: Guitars and Gear 1 05-07-2005 01:58 PM
wanted RG3120 (bolt on neck) atavachron Classified Ads: Guitars and Gear 0 03-13-2005 03:51 PM
Do I need a neck shim? giannifive Tech: Setup, Repairs and Mods 8 02-10-2005 04:39 PM
I refinished my neck - Bare wood & reshaped Les Paul 7-strin revsharp777 Tech: Setup, Repairs and Mods 2 12-19-2001 04:40 PM
Changing Vine inlay colors - things that make you go hmmmmmm tomizm Tech: Setup, Repairs and Mods 34 04-13-2001 03:14 PM
