Old 05-05-2006, 08:46 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
RG550 Action Problem
A couple of months ago, I bought my first RG from Eric's Guitars, a sponsor of Jemsite. It came set up perfectly, and I didn't have to touch a thing. However, I recently acquired another RG550 from a local pawn shop. This one was setup poorly, and the action was way too high.
So I immediately think, no big deal, I'll just lower the bridge. So I lowered the bridge to a reasonable heighth (a tad bit lower than normal), but I get all sorts of buzzing around the 14th fret. To get rid of this buzzing, I have to raise the bridge to a VERY high action that is unbearable for me to play at.
Finally, I messed around with the truss rod, as it seemed I had too much neck bow. This helped a little, but I still can't get rid of this buzzing without raising the action to an extremely high level.
How come I can't get the action that I have on my older RG?
What could be the culprit? Thanks.
Old 05-05-2006, 08:49 PM
jemsite  is offline
Administrator
Posts: 9,259  -  iTrader: (5)
Images: 11
Re: RG550 Action Problem
do the entire setup routine... in order.... but this worn or high fret(s) is the likely culprit... glen
Old 05-05-2006, 09:10 PM
waylay00  is offline
Yeah, I'll do that, and if it doesn't work, I'll probably end up taking it to a tech to see what he can do.
Old 05-05-2006, 09:15 PM
AleTheNervo  is offline
Posts: 459  -  iTrader: (0)
Probably the problem is the height of the 14th fret maybe it's too low...or the 15th is to high. You can control it by putting a ruler on the frets
Old 05-08-2006, 09:24 PM
PatrickSimsCustomShopUSA  is offline
Posts: 1,166  -  iTrader: (0)
Probably needs a fret job.....(Level the frets, recrown them, etc) Usually runs around $75. I've had the same problem before, your lucky its only one fret. It may also be less if its just one fret thats causing the problem.
neck bow, truss rod
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma JEM and Universe Guitars 89 06-18-2007 11:57 AM
High E string action problem John Tech: Setup, Repairs and Mods 22 06-08-2005 02:22 PM
bad tuning problem on an rg550 Ice_raven Tech: Setup, Repairs and Mods 5 09-19-2002 12:30 PM
Trem height and action problem. - Lowest possible trem heigh Theater of Dreams Tech: Setup, Repairs and Mods 2 04-29-2002 03:45 AM
Edge and Lo Pro Edge problems after action change - I don't Kremlin Tech: Setup, Repairs and Mods 13 07-20-2001 04:34 AM
