Old 06-24-2008, 09:52 AM
narmo  is offline
Posts: 11  -  iTrader: (0)
Question
RG550 and RG560 body differences
Hi,
what are the differences between these 2 body types?
Is the tone/volume/switch at same place?
Is there differences in the body shape?
How about the finish?
Im asking because i started to think of adjusting the pickup height.
In rg560 you cant screw the singlecoil pickups in there, cause they lay on the bottom already :/
Narmo
Old 06-24-2008, 12:10 PM
Matheau  is offline
Posts: 206  -  iTrader: (0)
Re: RG550 and RG560 body differences
Probably the same, just with different pick-up routing.
I'm guessing you were thinking of putting a pickguard on it. If you put a piece of foam behind the single coil, you can adjust it to whatever height you want. I did it on my RG-517 to get the single coil up to where I wanted it.
Old 07-19-2008, 02:04 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
The volume pot got moved at some point so a new pickguard may not align with the older 560. Any good luthier could route the pickup hole a little deeper if you need that. Body shape and finishes are all the same on the early RG5xx guitars. Slight changes for the newer AANJ versions.
coil pickup, pickup height
Differences between the Ibanez RG550 20th Ani. and the RG2550? deoreo J-Custom, USA Custom & Prestige Ibanez Guitars 25 11-01-2007 08:43 PM
RG550 - differences between '87 and '88? bikeman Other Ibanez Guitars (including Premiums) 27 04-10-2007 02:21 PM
RG550 and RG560 Bodies and Necks gpenguins Classified Ads: Guitars and Gear 0 10-23-2006 07:57 PM
WTT: RG550 body for RG560/RG570/RG5xx JiMoSiTY Classified Ads: Guitars and Gear 0 05-11-2005 10:43 AM
What are the differences btw RG550 and RG570? Bali2002 Other Ibanez Guitars (including Premiums) 10 09-06-2004 08:23 PM
