Old 02-20-2007, 11:01 PM
guitarnine  is offline
Posts: 4  -  iTrader: (0)
Rga121 pickup install help
Hello All,
I have decided to install a set of Tom anderson (H3,H1)pups in my Rga121NTF I heard that they sound good split as well, so i'm thinking (for some add'l tonal versatility) of replacing both (vol and tone)pots with push/pulls so i can split/select the coils ...question is which pots? would (CTS 500K, audio taper push pull) be correct? or do i need linear? should I keep the five way switch in there or replace with 3-way lever? What's your opinion? Do you have any experience with an RG or RGA similarly wired up? If so, any diagrams or links? I'm an electronics Tech, so the work should be relatively simple.
Thanks for any help.....
Pickup Wiring on RGA121 John01W Pickups & wiring 7 03-01-2006 05:39 PM
Breed bridge PU: describing the mids Ced777 Pickups & wiring 13 04-19-2004 05:49 PM
Pickup adjustment problem. RG-Head Tech: Setup, Repairs and Mods 2 01-29-2004 05:47 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 10:35 AM
Pickup Issue.. - Problem with wiring? MrBungle Pickups & wiring 5 04-15-2002 10:03 PM
