Old 03-16-2001, 04:47 AM
Erok  is offline
Posts: 18  -  iTrader: (0)
Rusting pup's - how to clean up and prevent
Hey Guys, any suggestions on getting the rust and crap off of my dimarzio's poll pieces? I've tried cleaning with Qtips and 3in1 oil... doesn't seem to help much. Can I coat them with something to stop it but not effect tone or output? Thanks!
Old 03-16-2001, 11:52 AM
Vaibanez  is offline
Posts: 814  -  iTrader: (5)
Rusting pup's
Here is a great topic to be added to the tech section on Jemsite. I've read a couple posts here and on the old site pertaining to this.
Here is how I do it and what you will need.
Needed:
1. A pair of vise grips, or similar locking pliers.
2. A dust rag or old T-shirt.
3. A Dremel or similar tool.
4. A small brass wire brush. Go to your local WallMart and get them. They are part of a metal polishing kit.
5. Black acrilyc paint. Aleen's works well and can be purchased at said WallMart
6. Hopies gun oil. Again, WallMart.
7. The allen(hex) wrench to remove the pole pieces. Or a screwdriver, depending.
How to:
1. With the allen wrench(screwdriver), remove the pole piece.
2. Using the vice grips and dust rag, lock the pole pice so that it is stable but not so tight that it mashes the threads. Use the rag to protect the threatds from the plier jaws.
3. Using the Dremel on the lowest speed, proceed to remove the rust from the pole piece. Don't use any more pressure than is needed to remove the gunk. Let the tool do the work and try hard to keep it steady.
4. Depending on how bad the pole piece was, you may find that the original finish has come of. Here is where the paint comes in handy. Don't dilute the paint. Use it full strength and dab it on. Set aside to dry.
5. If, when done, the original finish is fine, use the gun oil to coat the top 1/8" of the pole piece. Set aside to let the oil penitrate while you remove the next pole piece.
I have used this method before and have had excellent results.
J>
Old 03-16-2001, 02:25 PM
Kevan  is offline
deleted username
Posts: 1,429  -  iTrader: (0)
Rusting pup's
The bit to use on the Dremel are the wire brushes.
Dremel Part #'s:
Stainless Steel: 530, 531, 532
Brass Brushes: *535, 536, 537
http://www.dremel.com/html/products/.../cleaning.html
Another good paint to try out is the Krylon BBQ Grill paint. *It's a little more expensive than regular spray paint, but the finish looks close to the "matte black" on most gear, and it's durable (resists temperatures up to 1400F...for that gig you have next week on Venus).
Old 03-16-2001, 03:35 PM
bob oakman  is offline
Posts: 922  -  iTrader: (0)
Rusting pup's
Does crud and rust on the poll pieces affect the sound of the pup?
Old 03-16-2001, 05:04 PM
cmartin  is offline
Posts: 171  -  iTrader: (1)
Rusting pup's
Here's my technique, which probably is less involved and gives better results.
Replace the pole pieces.
Dimarzio generally uses socketset screws 10-32x5/8 with cup points for their pole pieces. You can get socketset screws in a number of colors, styles, etc. and should be able to match whatever you need for your pole pieces from a good hardware store.
Recently, I placed an order with the local Fastenal. They got them in the next day, and it only cost a couple of bucks.
Just take out the old ones and screw the new ones in.
Old 03-16-2001, 08:25 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
Rusting pup's
Once they are cleaned or replaced, (I recommend cleaning them with a scotch brite pad,) you can put a layer of clear nail polish over the poles. *I doesn't affect your tone, lasts a really long time, and is virtually impossible to notice visually. *This works especially well on the non-removable types of poles (the silver ones)
Jeremy
Old 03-18-2001, 05:19 AM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
Rusting pup's
Ok Jimm your hired expect a 20 lb box of pickups heading your way soon.........
Old 08-06-2008, 11:45 AM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Re: Rusting pup's - how to clean up and prevent
DISCLAIMER: I know this is a stupidly old thread, but anyway...
What about single coil pups' poles? you know, the kind that you cant take out of the pickup in order to clean?
Can a dremel with some of its tools do a nice job?
allen wrench
