Old 11-22-2007, 09:34 PM
Gwalchavad  is offline
Posts: 111  -  iTrader: (0)
S-540 Problems
Hello my fellow Ibanez users.
I have an S-540 from 1994/1995 if im right...I have a problem, after some years using 0.9 to 0.42, i´ve changed to 0.10 to 0.46.
Nothing new here...but my lo pro edge went beserk, then i did adjust the screws on the back and went well...but i have a serious doubt, what is the perfect height to use this strings on the S model???
I like low action, so what do you guys recomend?
I already have my springs 2 in diagonal, and 1 straigh like in the example (lol) / | \ ...
Should i put a 4rth spring???
Sorry for my english... :-)
Old 11-25-2007, 02:47 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: S-540 Problems
Hello! Yes, add another spring, it'll do the job. Good luck.
Old 11-25-2007, 06:28 PM
LonePhantom  is offline
Posts: 5,366  -  iTrader: (6)
Reviews: 98
Re: S-540 Problems
I have a couple of guitars with 10-52s and I have managed to balance the trem using only three springs parallel. Takes a little fiddling around, but you can definitely get there. Key is to make small quarter turn adjustments each time, and retune to pitch to see the result.
Old 11-25-2007, 08:11 PM
stratoskier  is online
Posts: 769  -  iTrader: (8)
Re: S-540 Problems
Since you stepped up a gauge in strings, you'll probably also need to tighten the truss rod. Did you do that?
Old 11-26-2007, 08:34 PM
Re: S-540 Problems
The truss rod was tighten...i ve crossed the springs and a miracle ocurred...
It tuned...lowered down the strings...and my baby is fast has hell... :-)
Another question...pickups height to strings... :-)
Cheers...
PS Thank you all
Old 11-26-2007, 08:41 PM
southpaw_lefty  is offline
Posts: 1,140  -  iTrader: (3)
Re: S-540 Problems
minor point, but you may need to adjust intonation as well
Old 11-26-2007, 09:18 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Re: S-540 Problems
Pickup height is a personal preference.
Jimmy
Old 12-01-2007, 01:45 PM
Jeremiah  is offline
Posts: 39  -  iTrader: (0)
Re: S-540 Problems
the closer to the strings the higher your output, but too close will pull on your strings with the pickups magnetic field and deaden sustain...
pickup height, pro edge, truss rod
Having problems with trem angle... Adagio_777 Tech: Setup, Repairs and Mods 13 09-20-2005 06:33 AM
Problems with EMG 85 pickup installation LonePhantom Pickups & wiring 12 08-23-2005 06:03 PM
new trem problems...from a different perspective btweensunandmoon Tech: Setup, Repairs and Mods 11 05-13-2003 12:47 AM
Problems with Rivera TBR-2SL Tube Head vaijem777 Gear and Equipment 6 04-14-2003 01:24 PM
tuning problems are over - new guitar chip james JEM and Universe Guitars 2 02-01-2001 10:48 PM
