Tech: Setup, Repairs and Mods
Saddle problem on Edge Pro
04-09-2005, 06:37 PM
ThomasBJ
Posts: 119 - iTrader: (
Hi! After getting my nut problem fixed I now have a new problem. Recently I have broken a couple of first strings (.009) and today I found out that the strings have cut small holes in the saddles. The guitar is about a year old and I think it is a little early to experience this kind of problem, so I was wondering if it's a common problem with the EP trem or I'm just unlucky? I guess i can file it away but with the pace it seems to have I might need changing saddles in a couple of years or so... Never had that problem with Lo
Pro Edge
... It seem as if the material is to soft for a string...
Thomas
ThomasBJ
Find all posts by ThomasBJ
04-10-2005, 05:36 PM
ryanb
Posts: 1,457 - iTrader: (
Re: Saddle problem on Edge Pro
What do you mean by "cut small holes in the saddles"? The string groove is supposed to be there. Where is the hole you are referring to?
ryanb
Find all posts by ryanb
04-11-2005, 12:01 PM
ThomasBJ
Okay now I've tried to draw it on this one...The string has cut through where the green line is in the red ring... LOL. I know it's a bad drawing but maybe you get the picture now? When strings cut marks like this they break very easy and i've had to change the first string once a week. And I haven't even used the whammy bar... And it's a nearly new guitar.
Is this a common problem or is it just me?
ThomasBJ
04-11-2005, 01:18 PM
evil_k666
Posts: 112 - iTrader: (
i haven't experienced any problem with the edge-pro at all (rg1550) yet i do know what you mean! i noticed that there are small marks, but i don't find them breaking my strings! my trem is floating perfect and i just love that guitar, yet it took me a while to figure out the perfect settings (
neck bow
, action, etc...)
evil_k666
Find all posts by evil_k666
04-11-2005, 09:10 PM
The Madness Here
Posts: 249 - iTrader: (
i've had a similar problem, but I wouldn't refer to them as 'holes,' they're burrs in the steel. The guy that works at our local ibanez retailer said this was a common problem on the earlier
edge pros
and has since been resolved. He said that he would order me some new saddles as soon as I give the word. I don't know if the salesmen around your area will do this though.
The Madness Here
Find all posts by The Madness Here
04-11-2005, 09:32 PM
ryanb
Yeah, it does sound like a sharp edge. You could try to clean it up with a small file if you can locate the sharp edge. But it would probably be better to just replace that saddle and try again.
ryanb
04-12-2005, 12:57 AM
Bezial
Posts: 540 - iTrader: (
had this on my jem and my rg , both new and after a few weeks i changed the strings , now when i bended a string i would hear a click , it was the same groove you are on about , i used a file to smooth the saddle and so far so good , i have changed strings heaps now and the problem hasnt returned.
Bezial
Find all posts by Bezial
04-12-2005, 08:50 AM
ThomasBJ
Thanks!
So this means that if I buy new saddles the problem shouldn't occur again?
ThomasBJ
04-12-2005, 01:44 PM
Posts: 19,350 - iTrader: (
The inserts are spun on a lathe and sometimes you'll get them with grooves left in them from machining. I seriously doubt the string did anything to the inserts, they're much harder than the string or the cast saddle the string used to rest on [and the string never cut a groove into the old saddles]
Swap it with a wound
string saddle
04-12-2005, 01:59 PM
ThomasBJ
You mean like swapping the saddle on the sixth-string with the saddle on the first-string?
ThomasBJ
04-12-2005, 02:11 PM
Yessss
04-12-2005, 03:05 PM
ThomasBJ
Cool! And thanks
ThomasBJ
edge pros
neck bow
pro edge
string saddle
how to set up a edge 3?
problem frequencies when mixing
is my edge trem bar in all the way
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault
leonard deroma
06-18-2007
11:57 AM
Double Edge Problem
aerocol
Pickups & wiring
10:26 PM
Lo pro edge & Double Edge in tune problem
Raffel
09:59 AM
edge tuning problem - edge tuning problem
johank
10:30 AM
11:04 AM
