Tech: Setup, Repairs and Mods
saddles not aligned - educate me
01-03-2002, 07:25 PM
yurich
Posts: 655 - iTrader: (
about my Floyd again...
(sorry if I got teh terminology all wrong)
- should the saddles in the trem be aligned with each other?
- why are there two spots for the "intonation lock screw" and which should I use?
why * *are they called that?
- a bit OT, but can I tighten the
trem arm
with the
arm holder
screw?
thanks
yurich
Find all posts by yurich
01-03-2002, 07:30 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
saddles not aligned
the saddles are not alligned across the strings, rather should be set for perfect INTONATION. The two holes for the inonation set screws allows the saddle to be placed where needed for intonation
...glen
jemsite
Find all posts by jemsite
01-03-2002, 07:42 PM
yurich
saddles not aligned
so you're saying I should just leave 'em like they are, they were set up this way on purpose? How do I know if right now it's set to correct intonation?
And what about that trem arm thingy?
yurich
01-03-2002, 07:45 PM
jemsite
Administrator
saddles not aligned
for intonation... see the TECH SETUP area of jemsite. i don't understand the trem bar question, but no doubt it's in the tech setup area
...glen
jemsite
01-03-2002, 07:50 PM
yurich
saddles not aligned
gotcha, I'll see what I can find there.
I'm talking about this little screw at the bottom of the arm holder. You can adjust it from the back, if you take the trem cover off. See, my bar is a bit loose so I was wondering if tweaking that sucker would do anything.
yurich
01-03-2002, 07:51 PM
jemsite
Administrator
saddles not aligned
the screw adjusts nothing
it simply holds the guide-wire that locks in the trem arm. Tech Setup area covers all this. Good luck... glen
jemsite
01-03-2002, 10:49 PM
Two hands31
Posts: 4,989 - iTrader: (
saddles not aligned
Quick intonation check (all guitarists should know this): *hit the 12th fret natural harmonic on a string, then fret the 12th fret on that string. *If both are the same, the intonation on that string is ok. *Do this to all the strings.
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
01-03-2002, 10:55 PM
Posts: 19,352 - iTrader: (
saddles not aligned
Accurate intonation. Tune the open string then fret the last fret on the board. Adjust as needed.
01-04-2002, 12:26 AM
yurich
saddles not aligned
but if I were to do that, I'd have to take the string off every time I have to adjust. What a pain in the a$$!!
Thanks for the tips
yurich
01-04-2002, 12:51 AM
saddles not aligned
You can slack the strings enough on all but the high e and b just by clamping the trem bar to the body and move the saddles. The e and b you'll have to slack with the tuners. Or you could buy an
intonation tool
and make it easy. You never have to remove the string to intonate either way.
It may be a pain but you only have to do it once so the effort really is worth it. The guitar will sound so much better in the upper registers you'll be amazed at the difference.
01-04-2002, 01:27 PM
big al
Posts: 222 - iTrader: (
saddles not aligned
Slightly off the subject...but will a standard $79 tuner be good enough for setting the intonation?
I have always used my trusty old chromatic tuner but I have often wondered how accurate it may be. Then again, how accurate is my playing?
What tuners seem to work the best?
big al
Find all posts by big al
01-04-2002, 02:50 PM
Two hands31
saddles not aligned
Rich on 9:55 pm on Jan. 3, 2002
Unless you have a 21 or 22
fret guitar
(like me). *
Two hands31
01-04-2002, 03:04 PM
saddles not aligned
It makes no difference how many frets you have, intonate to the last one. 22 frets? then high e is intonated to d when fretted at the 22nd, etc.
Strobe tuners must be nice but all I have is a Sabine 1000. It gets the job done. It may not be accurate to a hundreth of a cent, but it's accurate enough.
01-04-2002, 04:52 PM
Texter
Posts: 839 - iTrader: (
saddles not aligned
If your intonation is incorrect, your guitar will start to wobble a bit on high gain settings playing high notes. That's how you can get real close...and tone deaf, probably, if you don't get it at once. A little vibrato can do the trick as well. Sounds stylish for that matter
Texter
Find all posts by Texter
arm holder
fret guitar
intonation tool
strobe tuner
trem arm
new saddles or new bridge?
fender showmaster saddles
why is there a shim under my floyd rose saddles
how to install electric guitar bridge saddles
what size allen wrench is used on strat bridge saddles
05:07 PM
