Tech: Setup, Repairs and Mods
Same set of strings. Except a lot more tension??
Page 1 of 4
02-17-2011, 01:21 AM
AmazinAzian12
Posts: 549 - iTrader: (
Ok.I just bought a new
set
of
strings
. Dunlop Mediums. I have been using these for a while and they are great. But something weird has happened tonight while changing the strings.
Everytime I tune up to pitch, I strum and then they all go out of tune. I have stretched the snot out of these strings and I keep having to tune them up. Which also causes my Edge pro to go from flat "_" to a "/". Not as exaggerated as the example but it is pretty far up.
I don't know what is going on. I've never had this problem. Could it be a bad set of strings? Or bad springs. I bought a new set of springs a couple months back and they weren't showing this problem then. Why now?
AmazinAzian12
Find all posts by AmazinAzian12
02-17-2011, 04:51 AM
linuxpenguin
Posts: 3,922 - iTrader: (
Reviews: 11
Re: Same set of strings. Except a lot more tension??
1) floating trem system may be out of adjustment
2) if your temperature changed after changing them, it could have bowed your neck (i.e. you need truss rod adjustment)
3) combination of both.
linuxpenguin
Find all posts by linuxpenguin
02-17-2011, 09:44 AM
AmazinAzian12
I just don't know how it could be either one of those linuxpenguin.
AmazinAzian12
02-17-2011, 10:00 AM
AmazinAzian12
How could my Trem be out of adjustment when the string set is exactly the same and I never touch the trem springs? This is really frustrating me right now.
AmazinAzian12
02-17-2011, 10:07 AM
andrewsfury
Posts: 1,573 - iTrader: (
Reviews: 37
The new strings will have more tention.
what i do is set it up as close as possible stretch the strings good.
play the heck out of it for a few minutes then re set up. should be fine then.
sometimes they are tricky and others not so bad.
its just spring shock so give it enough time and patience and you will be fine.
andrewsfury
Find all posts by andrewsfury
02-17-2011, 10:29 AM
AmazinAzian12
I have never heard of the term "Spring Shock" before. Also I have never had this problem before. I have been tuning up to pitch multiple times and I have no idea when it will be fully in tune. It just keeps going out of tune. I feel like my bridge is going to pop off.
I guess I can't be sold on the fact that these strings are supposed to have "Low
Tension
& quick break-in time"
Also. Whenever I tune up the higher strings and get really close with the Machine heads, it makes a high pitch *ting* noise like i plucked the string behind the nut and it goes way sharp. What is that?
AmazinAzian12
02-17-2011, 11:40 AM
Hikey Mikey
Posts: 1,657 - iTrader: (
AmazinAzian12
I guess I can't be sold on the fact that these strings are supposed to have "Low Tension & quick break-in time"
It sounds like what happens when you install a set of unstretched strings and stretch them out with the tuners. Eventually they will stay in tune, but this isn't the best way, obviously. If you have used this brand before, and stretched them properly, then I'd say this set is defective or Dunlop changed them somehow. I'd try another set and if they behaved the same way, switch brands.
The "ping" noise is just some tiny part of the system (strings, bridge, nut, tuner) giving way to the increasing tension and settling into place. Again, it sounds like what happens if you put a brand-new unstretched string on and just start cranking the tuner.
Peace
Mike
Hikey Mikey
Visit Hikey Mikey's homepage!
Find all posts by Hikey Mikey
02-17-2011, 12:03 PM
nsabino
Posts: 493 - iTrader: (
Strings must be thoroughly stretched, especially the wrapped ones. I usually stretch 'em my pulling and bending, retuning play about a day without the nut locked and the next day bvasically do the same with lesse extreme to the pulling. After that they should be stretched and should stay in tune...
Regards,
Nelson
nsabino
Find all posts by nsabino
02-17-2011, 12:07 PM
andrewsfury
Reviews: 37
AmazinAzian12
GO TO IBANEZ RULES BANNER AT THE TOP. Read the tech\setup and you will understand. Rich saved my life on floating trems.
andrewsfury
02-17-2011, 12:17 PM
LonePhantom
Posts: 7,337 - iTrader: (
Reviews: 120
All the Dunlop strings I've played have had impressive stretch-in times. You may have been unlucky with one (this) set though. What technique are you using to stretch strings?
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
02-17-2011, 02:04 PM
AmazinAzian12
LonePhantom
I do what Rich says on his website. Well mostly. I will string the guitar up to pitch. Then stretch the strings by hand. Retune and repeat a few times. Then I will lock the pads and then go crazy with the whammy bar for a bit. Then unlock and retune. I repeat until there is little to no detune when i go crazy.
This time I can barely get the strings to all stay in tune after i do this. And The bridge is being pulled way up by them. I don't know how guitar center is with returning already used strings. I know they replaced my set of DR's when the high E broke off right when I strung it. But this situation is different.
AmazinAzian12
02-17-2011, 02:27 PM
AmazinAzian12
Here is how my bridge looks with the new set of strings fully tuned and locked up. They still wont stay in tune though. I have even let them sit over night and still having this problem.
AmazinAzian12
02-17-2011, 02:29 PM
andrewsfury
Reviews: 37
Its just spring shock i promise let it chill for a day.
springs have a memory and when you put new strings on and keep ****ing with it it is confused.
give it a day to communicate.
andrewsfury
02-17-2011, 02:39 PM
AmazinAzian12
Ok. I'll give it another day to sit.
AmazinAzian12
02-17-2011, 04:26 PM
linuxpenguin
Reviews: 11
AmazinAzian12
quit being stubborn and adjust your tremolo.
The tension may not be the exactly the same. You may have a defective set, or you got 9-46 instead of 9-42 on accident (ive done that...)
04:40 PM
linuxpenguin
Page 1 of 4
set
strings
tension
img=http://img523.imageshack.us/img523/4313/avonfmcfm1plusheadstockcloseup.th.jpg] (http://img523.im
site:www.jemsite.com jemsite "conned"
"DR Strings BLACK BEAUTIES - EXTRA-Life Black Coated Electric 10-52" review
muting strings noise up high the neck +left hand muting
strings tension
xklusivly4u
04:27 PM
Am I the only one that thinks DR Strings uses colors to cover poor quality strings?
Clonetool
37
07-19-2007
02:58 PM
string tension and spring tension
choubix
03:21 PM
Bar Tension
Ozzdoc
02:17 PM
Tension Question
parker_fly
10:05 PM
07:02 AM
