Same set of strings. Except a lot more tension?? - Jemsite
post #1 of 47 (permalink) Old 02-17-2011, 01:21 AM Thread Starter
Exclamation Same set of strings. Except a lot more tension??
Ok.I just bought a new set of strings. Dunlop Mediums. I have been using these for a while and they are great. But something weird has happened tonight while changing the strings.
Everytime I tune up to pitch, I strum and then they all go out of tune. I have stretched the snot out of these strings and I keep having to tune them up. Which also causes my Edge pro to go from flat "_" to a "/". Not as exaggerated as the example but it is pretty far up.
I don't know what is going on. I've never had this problem. Could it be a bad set of strings? Or bad springs. I bought a new set of springs a couple months back and they weren't showing this problem then. Why now?
AmazinAzian12 is offline
post #2 of 47 (permalink) Old 02-17-2011, 04:51 AM
Reviews: 11
Re: Same set of strings. Except a lot more tension??
1) floating trem system may be out of adjustment
2) if your temperature changed after changing them, it could have bowed your neck (i.e. you need truss rod adjustment)
3) combination of both.
linuxpenguin is offline
post #3 of 47 (permalink) Old 02-17-2011, 09:44 AM Thread Starter
I just don't know how it could be either one of those linuxpenguin.
post #4 of 47 (permalink) Old 02-17-2011, 10:00 AM Thread Starter
How could my Trem be out of adjustment when the string set is exactly the same and I never touch the trem springs? This is really frustrating me right now.
post #5 of 47 (permalink) Old 02-17-2011, 10:07 AM
Reviews: 37
Smile Re: Same set of strings. Except a lot more tension??
The new strings will have more tention.
what i do is set it up as close as possible stretch the strings good.
play the heck out of it for a few minutes then re set up. should be fine then.
sometimes they are tricky and others not so bad.
its just spring shock so give it enough time and patience and you will be fine.
andrewsfury is offline
post #6 of 47 (permalink) Old 02-17-2011, 10:29 AM Thread Starter
I have never heard of the term "Spring Shock" before. Also I have never had this problem before. I have been tuning up to pitch multiple times and I have no idea when it will be fully in tune. It just keeps going out of tune. I feel like my bridge is going to pop off.
I guess I can't be sold on the fact that these strings are supposed to have "Low Tension & quick break-in time"
Also. Whenever I tune up the higher strings and get really close with the Machine heads, it makes a high pitch *ting* noise like i plucked the string behind the nut and it goes way sharp. What is that?
post #7 of 47 (permalink) Old 02-17-2011, 11:40 AM
It sounds like what happens when you install a set of unstretched strings and stretch them out with the tuners. Eventually they will stay in tune, but this isn't the best way, obviously. If you have used this brand before, and stretched them properly, then I'd say this set is defective or Dunlop changed them somehow. I'd try another set and if they behaved the same way, switch brands.
The "ping" noise is just some tiny part of the system (strings, bridge, nut, tuner) giving way to the increasing tension and settling into place. Again, it sounds like what happens if you put a brand-new unstretched string on and just start cranking the tuner.
Peace
Mike
Hikey Mikey is offline
post #8 of 47 (permalink) Old 02-17-2011, 12:03 PM
Strings must be thoroughly stretched, especially the wrapped ones. I usually stretch 'em my pulling and bending, retuning play about a day without the nut locked and the next day bvasically do the same with lesse extreme to the pulling. After that they should be stretched and should stay in tune...
Regards,
Nelson
nsabino is offline
post #9 of 47 (permalink) Old 02-17-2011, 12:07 PM
Reviews: 37
GO TO IBANEZ RULES BANNER AT THE TOP. Read the tech\setup and you will understand. Rich saved my life on floating trems.
post #10 of 47 (permalink) Old 02-17-2011, 12:17 PM
Reviews: 120
All the Dunlop strings I've played have had impressive stretch-in times. You may have been unlucky with one (this) set though. What technique are you using to stretch strings?
LonePhantom is offline
post #11 of 47 (permalink) Old 02-17-2011, 02:04 PM Thread Starter
I do what Rich says on his website. Well mostly. I will string the guitar up to pitch. Then stretch the strings by hand. Retune and repeat a few times. Then I will lock the pads and then go crazy with the whammy bar for a bit. Then unlock and retune. I repeat until there is little to no detune when i go crazy.
This time I can barely get the strings to all stay in tune after i do this. And The bridge is being pulled way up by them. I don't know how guitar center is with returning already used strings. I know they replaced my set of DR's when the high E broke off right when I strung it. But this situation is different.
post #12 of 47 (permalink) Old 02-17-2011, 02:27 PM Thread Starter
Here is how my bridge looks with the new set of strings fully tuned and locked up. They still wont stay in tune though. I have even let them sit over night and still having this problem.
post #13 of 47 (permalink) Old 02-17-2011, 02:29 PM
Reviews: 37
Its just spring shock i promise let it chill for a day.
springs have a memory and when you put new strings on and keep ****ing with it it is confused.
give it a day to communicate.
post #14 of 47 (permalink) Old 02-17-2011, 02:39 PM Thread Starter
Ok. I'll give it another day to sit.
post #15 of 47 (permalink) Old 02-17-2011, 04:26 PM
Reviews: 11
quit being stubborn and adjust your tremolo.
The tension may not be the exactly the same. You may have a defective set, or you got 9-46 instead of 9-42 on accident (ive done that...)
set , strings , tension
Human Verification
strings tension xklusivly4u Tech: Setup, Repairs and Mods 18 01-15-2008 04:27 PM
Am I the only one that thinks DR Strings uses colors to cover poor quality strings? Clonetool Tech: Setup, Repairs and Mods 37 07-19-2007 02:58 PM
string tension and spring tension choubix Tech: Setup, Repairs and Mods 4 06-11-2007 03:21 PM
Bar Tension Ozzdoc Tech: Setup, Repairs and Mods 7 07-22-2005 02:17 PM
Tension Question parker_fly Tech: Setup, Repairs and Mods 4 05-18-2005 10:05 PM
