Old 05-30-2008, 03:46 PM
DarthLamer  is offline
Posts: 108  -  iTrader: (0)
Question
Scarf joint crack
I've read a few threads on here regarding scarf joint/headstock cracks. In addition, I've noticed numerous necks on the bay that have this type of crack. Is this the result of not taking care of the instrument, dropping it, or even overtightening the locking nut's screws? Surely this is avoidable...
I have a 1998 RG570, that doesn't have this crack. In recently having purchased a 1999 RG7620, and hoping to maintain the quality of both of these instruments, these types of cracks concern me.
Old 05-30-2008, 04:16 PM
CosmicDebris  is online
Posts: 3,216  -  iTrader: (4)
Re: Scarf joint crack
The Original neck in my 88' 550 broke cause my girlfriend and I at the time rolled on top of it. It broke just at the same place as what your talking about. The replacment neck which is a 91 does not have this prob.
Perhaps it is a week spot that falls prey to alot of major wammy pull ups which greatly increases the stress where the strings lock down.
Old 05-30-2008, 07:36 PM
frankfalbo  is offline
It falls prey to anything and everything. It's an extremely weak point, and can develop cracks without any provocation. You just look down one day and notice that it's started to crack a little.
One thing you can do to prevent them or stop them from growing is to take the nut off, and (very carefully) soak a little thin CA (superglue) into that entire area. It will penetrate the wood grains around there and "plasticize" or petrify those fibers, and should prevent any cracking. They've likely got some neck finish in there, so you could dremel it a little, but that's counterproductive. There's likely tiny fissures that will allow the CA to penetrate into what could be future problem areas. If it's absolutely loaded with finish (or painted like the RGT's) then the CA would be wasted, so you can leave it alone.
Those cracks aren't guaranteed to occur by any means. I've got 1987 necks that are still clean.
neck finish, scarf joint
Scarf Joint Axayacatl JEM and Universe Guitars 11 03-01-2007 09:38 AM
The new 3 maple pieces neck it is better than scarf joint? Kurt76 Other Ibanez Guitars (including Premiums) 6 11-26-2005 09:15 PM
"vertical" crack at the scarf joint? marianozz Tech: Setup, Repairs and Mods 6 07-14-2004 05:15 PM
Scarf Joint crack Vai the god of Sound Tech: Setup, Repairs and Mods 2 05-09-2002 01:18 PM
Neck joint crack on older Jems - What is this "neck joint cr Matt55655 JEM and Universe Guitars 1 03-07-2001 12:33 AM
