Old 05-02-2002, 01:13 PM
Vai the god of Sound  is offline
Posts: 232  -  iTrader: (0)
Scarf Joint crack
I have a crack outlined around the scarf joint on my Jem77FP. It goes right up to the bottom of the fret board. How could I repair this myself...I'm on a tight budget, but if it's sincerely required to take it to the shop, I will dish out the cash for it.
Would a simple glueing inside the cracks and then viced for 2 days help?
I'm too scared to use the floyd on it now because of the pressure. It effects the neck somewhat as the headstock is tilted back a bit further than 13º. It's causing a buzz on the first fret for some of the strings.
Old 05-02-2002, 02:34 PM
ripl3y  is offline
Posts: 747  -  iTrader: (0)
Firstly I'd de-string it, take the pressure off to get a clearer idea of the actual damage.
You could inject some glue into it, the type of glue depends on your climate, if your climate is hot then maybe a good strong hide glue would be appopriate, it withstands the heat better, other than that Titebond would be a good substitute.
Try to fashion a support out of wood or cork that follows the contours of the neck before clamping it.
I'm not really a repair man and if you're really concerned about it i'd speak to Brian (Universal Jems) or Jeremy (LGM Guitars).
Check out some pro advice here:-
http://www.frets.com/FRETSPages/Luth...neckcrack.html
http://www.frets.com/FRETSPages/Luth...pipette01.html
http://www.frets.com/FRETSPages/Luth.../gluetest.html
At this link scroll down to "Items For Luthiers", they have a "Broken Headstocks" section:-
http://www.frets.com/FRETSPages/pagelist.html
Good Luck
Steve
Old 05-09-2002, 01:18 PM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
I had an RG that had a serious crack like this...I used Titebond wood glue and a clamp, and it worked fine. Steve has some good advice. The question is whether you can get glue into the crack.
Greg
fret board, lgm guitars, scarf joint
