Tech: Setup, Repairs and Mods
Self Glued Neck
03-15-2008, 10:51 AM
spkenn5
Posts: 656 - iTrader: (
Self Glued Neck
Hey guys, have you guys encounter this problem? I just recently found out why my strat isn't always in tune. i found out the neck was glued on to the body, it seems like it was self glued. so i can never get the G string sound "right" always half step up. so i wonder how to get rid of the glue? should i attempt to melt them? ( im still not sure because i might damage the finish of the body. )
spkenn5
Find all posts by spkenn5
03-15-2008, 10:58 AM
Scali
Posts: 570 - iTrader: (
Re: Self Glued Neck
I don't really get it...?
Even if the neck is glued, it should still be in the right spot, since the screws are still in there, right?
And if it's not in the right spot, shouldn't it affect all strings, rather than just the G-string?
It sounds more like the
bridge saddles
need intonation than that the neck would somehow not be put on right?
So well, have the guitar looked at before you try to melt glue and damage the guitar or anything.
Scali
Visit Scali's homepage!
Find all posts by Scali
03-15-2008, 11:07 AM
spkenn5
Re: Self Glued Neck
I brought it to the tech, that's what they say to me. So I guess I'll try to have it seen by someone else.
spkenn5
03-15-2008, 11:08 AM
Algiman
Posts: 2,552 - iTrader: (
Re: Self Glued Neck
Whatever is causing your tuning problems, it isn't the glue.
It is difficult to diagnose that sort of problem without seeing the guitar, but I'd start by making sure the string isn't binding in the nut.
Algiman
Find all posts by Algiman
03-15-2008, 11:29 AM
spkenn5
Re: Self Glued Neck
great idea, i'll take a pic and have it seen by you guys first..
spkenn5
03-15-2008, 05:02 PM
losgatosrg350dx
Posts: 848 - iTrader: (
Re: Self Glued Neck
a glued joint has more density and more strength than a non glued joint
that is properly
the glue if done and used correctly, will always have a dense and crisp sound to it, as without it it would sound a bit more mellow
take it to a better tech, he might be fiucking with you when all you need to do is intonate it
losgatosrg350dx
Find all posts by losgatosrg350dx
03-15-2008, 05:03 PM
elcid
Posts: 8,718 - iTrader: (
Re: Self Glued Neck
oh...my....God....
You actually spelled out "you" and typed at a coherent adult level.
Kudos to you gatos, you are on your way to becomming a man.
05:17 PM
elcid
Find all posts by elcid
03-15-2008, 05:19 PM
newbieguitarmaker
Posts: 4,030 - iTrader: (
Re: Self Glued Neck
elcid
oh...my....God....
u r stupdi
ya I agree with you guys on this one, check the bridge
newbieguitarmaker
Find all posts by newbieguitarmaker
03-15-2008, 07:20 PM
markyperfection
Posts: 233 - iTrader: (
Re: Self Glued Neck
elcid
oh...my....God....
he's getting there, now we just have to work on everything he posts being complete and utter b.s., previous post included.
markyperfection
Visit markyperfection's homepage!
Find all posts by markyperfection
03-15-2008, 08:10 PM
ryanb
Posts: 1,457 - iTrader: (
Re: Self Glued Neck
markyperfection
That pretty well covers it...
ryanb
Find all posts by ryanb
03-15-2008, 08:18 PM
elcid
Re: Self Glued Neck
markyperfection
Baby steps, man. Baby steps.
elcid
03-15-2008, 08:36 PM
moebius
Posts: 2,041 - iTrader: (
Re: Self Glued Neck
Punctuation is next hopefully.
moebius
Find all posts by moebius
03-16-2008, 12:13 PM
losgatosrg350dx
Re: Self Glued Neck
markyperfection
get of my toes and focus on other things......nothing about me is bs...or anything i post im tired of your lies and you assuming soo much about me.....your a low person, so keep you negativity to urself
losgatosrg350dx
03-16-2008, 12:56 PM
elcid
Re: Self Glued Neck
see man you almost got "your" right it should be you're but you almost had enough letters. Urself on the other hand is a complete trainwreck.
elcid
03-17-2008, 09:59 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Self Glued Neck
Edited for niceness
Jimmy
10:51 AM
jb4674
Find all posts by jb4674
bridge saddles
finger board
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Jem555 Wizard neck?
Thared33
01:32 AM
Damaged Neck Screw Holes On My Body
Eddie_V_H
04:03 AM
Very loose neck to neck pocket fit, what do I do?
SilverSurfer2
10:00 PM
Removing the Neck on a 7DBK!!!
Chipiem
04:53 AM
Changing Vine inlay colors - things that make you go hmmmmmm
tomizm
34
04-13-2001
03:14 PM
10:47 PM
