Old 01-23-2005, 10:26 AM
anonymousrg  is offline
Posts: 2  -  iTrader: (0)
Serious trem. angle problem with Edge bridge
Hi.
I own an Ibanez RG 550 ex and I've got a problem with the (floyd rose) edge bridge on it.
The bridge is raised quite a bit above normal, and the two screws underneath are screwed all the way in, so I have no way(?) of lowering it. I use 0.01 strings and standard EADGBE tuning.
I've read the guides both here and on ibanezrules.com, but it doesn't help me since, as I said, the screws underneath cannot be tightened any further.
What may have caused this, and how do I fix it?
Old 01-23-2005, 02:35 PM
Azrael  is offline
Posts: 403  -  iTrader: (0)
Re: Serious trem. angle problem with Edge bridge
Nothing has caused it......it's very normal. Just put and extra spring in the spring cavity, adjust and you'll be fine.
Old 01-23-2005, 06:55 PM
Thanks for your reply. It only fits three springs, but I changed the middle one, and it works great now.
edge bridge, floyd rose, spring cavity
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
Ibanez JS1000 BTB (pics and new Edge Pro trem!) EXCrosslink JS (Satriani Model) Ibanez Guitars 39 09-08-2003 02:08 PM
JS2000CG FX Edge bridge? NOTP JS (Satriani Model) Ibanez Guitars 1 03-31-2003 01:07 AM
Can't get edge trem in adjustment - always too high, too low bduersch Tech: Setup, Repairs and Mods 4 11-19-2001 12:37 AM
