Tech: Setup, Repairs and Mods
Setting an Edge Pro
05-18-2006, 01:55 AM
Ironjose
Posts: 1,060 - iTrader: (
Setting an Edge Pro
Hey guys, tonight it got me to setup my axe, you know, action, intonation and the chapstick hint... anyways i was wondering if the trem should be kept in angle but not towards or backwards, i mean from the trebel strings to the bass strings, from factory it came that way:
bass strings down to the trebel strings.
how should i do it?
JJ
Ironjose
Find all posts by Ironjose
05-18-2006, 04:02 AM
Bezial
Posts: 540 - iTrader: (
Re: Setting an Edge Pro
i think i understand, you mean the angle it lays from bass to treble? if so that isnt cruitial (hope im right) its the hight of the strings and thats a personal thing , as long as all sounds ok thats all thats important there.
again i think im righ here but im sure i will be the next to know if im wrong
Bezial
Find all posts by Bezial
05-18-2006, 09:53 AM
HSH
Posts: 499 - iTrader: (
Rich's site (Ibanez Rules) has GREAT tech info on guitar setup.
HSH
Find all posts by HSH
05-18-2006, 10:45 AM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
That angle is only crucial to the point of the strings not buzzing and it is very commen for the treble side to be lower than the bass cause they oscilate in a smaller radius (hope that makes sense)
brothersnowgone
05-18-2006, 03:28 PM
nightfiend14
Posts: 1,005 - iTrader: (
brothersnowgone
angle is part of how much pull up or dive you want as well, if you don't start with a neutral position you are limiting the amount of one or the other, but that is preference mainly.
nightfiend14
Find all posts by nightfiend14
05-18-2006, 03:44 PM
brothersnowgone
Reviews: 7
nightfiend14
The angle he is talking about is for action and on an Ibanez (at least all of my edge equipped Ibanez's) that angle can be set to both extremes (meaning highest action to achieve no buzz and lowest action to get great playability) and you can still have max pull up and dive to the point of the
trem block
hitting the front and back of the route. We were talking about the angle from side to side not front to back.
04:29 PM
brothersnowgone
05-18-2006, 10:33 PM
Ironjose
thanx for the replies, i´m talking about the angle side to side, but i didnt think about the pull or push of the trem, but yes i also forgot to mention is the action i´m worry about, i set all my guitars but with this one i´m kind of worry i mess it up and i dont want that...
JJ
Ironjose
05-19-2006, 12:56 AM
brothersnowgone
Reviews: 7
I wouldn't worry if I were you, it just takes some time and patience. Is this your first time setting up a floating trem? If it is it's best to learn now so you don't throw money away paying for setups. Like HSH said go threw rich's tech area and you'll get to know all your guitar's better. Setting action so you get it exactly how you like is easily one of the hardest thing to get right when you first start setting up your own guitar's, but after a while you get better and better. The way I use to setup my guitar's compared to how I set them up now is very different, I gradually was able to get my action lower and lower until now it's perfect. If your really nervous about messing it up, just make a lot of fine measurements (preferably with a feeler gauge).
http://www.jemsite.com/tech/4tech.htm
You can print this out or save it to your computer and enter in your own measurements. Good Luck.
brothersnowgone
05-19-2006, 11:23 PM
Ironjose
well this isn´t my first time setting up a guitar... this is my fifth guitar and the third with
floyd rose
o similar, but the other two i just dont mind as much as this one... the cost isnt similar at all by far... so that´s worries me.
i think i have a great setup of the other two but i think they work for me, al though i think also that the neck on my other ibanez isnt as good as this one so... this axe should be easy to set.
where can i find the Rich´s tech area?
JJ
Ironjose
05-19-2006, 11:37 PM
brothersnowgone
Reviews: 7
brothersnowgone
05-21-2006, 03:28 AM
Ironjose
thanx... i´ll check it out
JJ
Ironjose
floyd rose
trem block
will edge zero pro fit edge 3 route?
how to set up a edge 3?
how to get a korn setting
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
Questions about setting up my Edge Pro trem
billyboy
09:55 PM
How to setting up my Edge Pro tremolo?PLS!
dimitar
02:17 PM
Setting up Edge Pro angle
rrhea
12:02 PM
Need help setting Origional Edge on Jem555
_Final_Warning_
10:53 AM
02:08 AM
