Old 09-23-2003, 05:24 PM
6StringGod  is offline
Posts: 123  -  iTrader: (0)
Setting Trmeleo angle
Ok so i have the original edge on my Rg570. It says the bottom of it should be parallel with the body right? Now I need to set the action by the bridge height. On the jemsite tech section it says to Loosen the bridge stud set screw on each stud a few complete turns counterclockwise with a 1.5 mm allen wrench, well when i do that it doesnt seem like I'm turning anything. Can anyon give me more info on how to do this? thanks
Old 09-24-2003, 04:02 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
you mean the Allen key turns loose, or the set screw is kind of locked?
Old 09-26-2003, 02:39 AM
the setscrew seems locked... it doesnt feel like im turning anything at all and i cat really see inside the post (i think thats what it is )... so any ideas?
Old 09-26-2003, 12:47 PM
nuno  is offline
you got the Allen key 'grabbing' the set-screw's hex-slot but it's kind of stiff to loose. did i understand well?
if so, give the stud a little turn anti-clockwise. this should unlock the set-screw.
if this doesnt work, spray some WD40 down into the set-screw hole. then try again.
Old 09-26-2003, 04:05 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
I think he means it's just spinning [which means it wasn't tight to begin with] in which case you should be able to lower the studs no problem
Old 09-26-2003, 06:49 PM
ok.. well then do i have to tighten it back up afterwards?
Because my guitar teacher lowered the action for me with no trouble but, the angle is wrong (he was used to the original floyd roses and not the edge) So I need to make the angle higher, then the action will raise aswell. But the only thing im concerned about is the action is as low as it could go so once i change the angle is it going be able to go back to wear it is now? Sorry for my ignorance... thanks!
Old 09-26-2003, 08:18 PM
Rich  is offline
The guitar needs a neck shim like most older ibanez
Old 09-27-2003, 02:48 AM
is that hard to put in?
How much would it be to send the guitar to you for a complete setup?
Old 09-27-2003, 03:03 AM
Rich  is offline
More than you want to pay.
Pull the trem w/ strings on, pull the neck. Cut a 3/8" strip off one end of a buisness card and tape it in the neck pocket at the neck p/u end of the pocket. Put everything back together.
Old 09-27-2003, 03:18 AM
alright i'll try it... thank you.
allen wrench, floyd rose, neck shim
