Old 10-23-2007, 07:47 PM
shreddingjoris  is offline
Posts: 144  -  iTrader: (0)
Setting up a neck help pls
hey, the neck of my old ibanez is getting
a bit like that, (not that extreme)
i have never set up a neck anyone can give me some advice? do i need to remove ever string first? it's a tremolo
Old 10-23-2007, 07:55 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Setting up a neck help pls
You probably just need a truss rod adjustment.
Which way is up in that picture? Is that bump on the bottom a nut pointed down (and the neck is backbowed), or is the neck facing upward (and the neck is front-bowed)? If it is backbowed, loosen the rod. If it is front-bowed, tighten the rod.
rod adjustment, truss rod, truss rod adjustment
Evolution Neck as a Bridge w/ PAF Pro Neck t1r12003 Pickups & wiring 6 12-03-2007 07:38 PM
FS: 1994 Fender Strat Neck with Rosewood Fretboard Queens_Brian_May Classified Ads: Guitars and Gear 1 07-20-2007 05:51 PM
Damaged Neck Screw Holes On My Body Eddie_V_H Tech: Setup, Repairs and Mods 10 04-11-2007 04:03 AM
Hands of ACID on a jem7vwh neck ZaPeRoN JEM and Universe Guitars 8 11-06-2005 08:16 AM
What is the best way to drill neck holes in new body..... SilverSurfer2 Tech: Setup, Repairs and Mods 10 04-14-2003 06:41 PM
