Old 06-28-2008, 04:13 PM
acdc51502112  is offline
Posts: 44  -  iTrader: (0)
Setting up Edge with hybrid strings
hey guys i need some help with setting up the string tension for hybrid strings. Would I have to change the pattern of the springs (eg have one on the low end and two on the high end) or is it fine with and even amount on both sides? thanks.
Old 06-28-2008, 04:47 PM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
Re: Setting up Edge with hybrid strings
I'd imagine the springs woul be fine the way they are, you'd just have to tighten the screw on the claw a little more on one side.
Old 06-28-2008, 09:07 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
I just switched to hybrids on my RG550. I didn't have to do anything differently than if I were switching normal gauge strings. I just drilled the trem claw in a little bit (not slanted in one direction, just straight like normally).
trem claw
Setting an Edge Pro Ironjose Tech: Setup, Repairs and Mods 10 05-21-2006 03:28 AM
Questions about setting up my Edge Pro trem billyboy Tech: Setup, Repairs and Mods 7 04-05-2006 09:55 PM
Question about setting up intonation with Edge tool... mityjoeyoungxnj Other Ibanez Guitars (including Premiums) 3 10-31-2005 10:04 AM
Setting up Edge Pro angle rrhea Tech: Setup, Repairs and Mods 3 05-15-2004 12:02 PM
Need help setting Origional Edge on Jem555 _Final_Warning_ Tech: Setup, Repairs and Mods 3 09-11-2002 10:53 AM
