Tech: Setup, Repairs and Mods
Skink Stripe Repair
03-10-2005, 08:01 AM
whatshisname
Posts: 882 - iTrader: (
Skink Stripe Repair
I picked up an RT150BK, yesterday, and the only problem I'm having with it is, that the skunk stripe has lifted a bit. It's not loose, and will not push back in. It's only up towards the top, starting around the fifth fret. The very top, and rest of the bottom, are fine.
What should I do? Heat gun? Sand the problem area even? Honestly, it's not THAT bad, and if I could deal with it as it is, but, of course, I'd much rather not.
Any advice is appreciated! Thanks!!
whatshisname
Find all posts by whatshisname
03-10-2005, 08:18 AM
Shep
Posts: 542 - iTrader: (
Re: Skink Stripe Repair
thing's like this can be a real problem to fix.
you could remove the
fret board
and re-glue the piece back in place with clamp's holding it all in place.
you might even hav to rip the whole strip out and start from scatch because it might be abit hard to glue the bit at the top and get eonght glue in place.
it's alot eazyer to go to a to your
local guitar shop
and ask for help or who can do it for you. as it's not that fun
Shep
Find all posts by Shep
03-10-2005, 08:23 AM
whatshisname
Eh, I was hoping it would be a much easier fix...
Thanks for the reply, though.
Would there be any harm in just trying to sand it flush? Like I said, it's not really THAT bad. (Just hoping!)
(Oh yeah, that should be skUnk stripe... DOH!
whatshisname
03-10-2005, 08:31 AM
Shep
skunk stripe is there not just for show it's a very hard wood so it provide's support on the neck and stop's it warping. if you sand it, it will loose some of it's stenght and will be alot more prone to warping.
how many mm is it hang out?.
Shep
03-10-2005, 09:04 AM
whatshisname
Yeah, I was worried about losing strength, but it is only hanging out a 16th of an inch, at the most, if that. Like I said, it's only one part of it that's sticking out. Would I really be taking that big of a chance, for such a small area?
If I would be, then I'll just have to suck it up, and do it right!
whatshisname
03-10-2005, 11:48 AM
frankfalbo
Posts: 1,875 - iTrader: (
Shep
That's not really accurate. The skunk stripe is just there as a means of installing the
truss rod
. That's what it has been doing since the first maple necked Fenders. It's usually walnut, a wood that isn't any harder than maple. Sanding it, and losing strength is not a concern. The question is why has it come out? It could just be swelling of the wood, (or shrinking of the maple) but since it starts at the 5th and expands, I'd say the glue joint has come free and needs to be repaired. One reason it might not go back in right now is that the truss rod is putting pressure on it.
If it were mine, I'd take the strings off, loosen the truss rod to have no pressure, and see (using clamps and protective cauls) if it could press back in under pressure. If it still couldn't, I'd saturate the area around it with thin superglue so it would penetrate and at least lock the stripe in its current location. Then I'd file it flat.
frankfalbo
Find all posts by frankfalbo
03-10-2005, 11:52 AM
Posts: 19,350 - iTrader: (
On some models [like a JS] that's true, on some, like a 7620, the bubinga is like the 2nd piece of a 3 piece neck, it runs all the way through to the fretboard and isn't just a fillet.
03-10-2005, 12:25 PM
whatshisname
Well, I already tried loosening the truss rod, and seeing if I could push it back in. That was actually the first thing that I thought of doing.
I thought that maybe the truss was overtightened, and that was what caused the problem. Does that make any sense?
I'll mess with it some more when I get home, and see what I can do. If not, I'll saturate it with glue, and file it down.
Thanks everyone!
whatshisname
03-10-2005, 01:49 PM
frankfalbo
Yeah, when you say "skunk stripe" it usualy refers to the thin truss rod filler strip. I'd refer to the bubinga as a neck lamination. Like the newer 3-piece
maple necks
. The RT150 is a regular skunk stripe.
frankfalbo
03-10-2005, 01:53 PM
Yup, just making sure the masses reading a year from now didn't misconstrue
03-10-2005, 02:07 PM
whatshisname
I do realize that it wouldn't affect the strength of the neck, but, I was more concerned over the stripe, itself.
For one thing, I was worried that it wouldn't be strong enough to take the rods pressure. Also, there was concern over how it would affect the movement of the rod, and it's ability to keep the neck in check. I take it now though, that these really aren't issues, since the amount of wood that I would need ro remove is so small?
whatshisname
03-11-2005, 01:24 AM
Shep
i meant the think lump of wood running up the neck like in some jem's, js's and rg's. thats a half an inch think, not the thin stipe wat's is used in strats.
sorry for that
Shep
03-11-2005, 01:29 AM
Shep
thats the case with alot of rg's jem's and js's
it does provide streght.
Shep
03-11-2005, 01:51 AM
It's just a fillet on a JS.
03-11-2005, 01:59 AM
Shep
yes . spot on
Shep
fret board
guitar shop
local guitar shop
maple neck
maple necks
truss rod
what is Bubinga stripe
how to repair a preamp
how to skunk stripe
guitare paint stripe
how to repair an ibanez jem 90 ham finish
Mesa Boogie Repair Needed - Your Opinions Wanted
bpd111
Gear and Equipment
11:14 AM
repair problems with an Ergodyne EDR 470 EX
unicorn220
Comments to Ibanez
02:25 PM
Taylor Warranty Repair Etc...
vwall
02:40 AM
Trem Post Repair. - Costly? Trade In?
eyeh8u
12:43 AM
Skunk stripe or Not? - why the "stripe"?
SilverSurferII
Archived Topics and Common Questions - GO HERE FIRST
06:50 PM
05:36 AM
