Old 06-28-2008, 12:47 AM
AmazinAzian12  is offline
Posts: 549  -  iTrader: (0)
So yea, strings and intonation?
So yea im still experimenting with string gauges since im trying to find out what gauge i should use to remove the buzz on my EAD strings. im now using 9-50 dimebag signature DR's and they sound great. but the intonation is off. so does that mean i have to get my jem intonated again? it was fine with the 9-46(i think so but it was a while ago). but i got a lot of buzz on the EA and D strings.
any knowledge?
Old 06-28-2008, 12:50 AM
jaxadam  is offline
Classified Watchdog
Posts: 3,043  -  iTrader: (9)
Re: So yea, strings and intonation?
Buzz doesn't have anything to do with intonation.
What are you tuned to?
Changing string gauges, and tuning the same can result in intonation problems. If you're using heavier strings on the bottom, and getting buzz on the bottom, you may need to raise your action on the lower strings.
Old 06-28-2008, 01:05 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Bingo
Old 06-28-2008, 01:33 AM
Rachmaninoff  is offline
Posts: 567  -  iTrader: (0)
Images: 5
Reviews: 11
If raising strings doesn't work, check the neck relief (probably a tiny adjustement, if any).
Old 06-29-2008, 06:28 AM
Mike239  is offline
Posts: 402  -  iTrader: (0)
Reviews: 6
Yeah String Buzz has nothing to do with what gauge or strings you use, give your guitar a good setup and say goodbye to your string buzz.
Old 06-29-2008, 02:28 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Actually, the lighter the strings, the more potential for string buzz, as they aren't as tight and have a bit more "flop" to them. But yeah, as long as you have your guitar set up correctly, then there shouldn't be much buzz.
Old 10-21-2008, 01:39 AM
emmarvz  is offline
Posts: 5  -  iTrader: (0)
Hi guys,
I just have a new RG1570 guitar...haven't replaced the strings yet and I want to change the strings with the same string set and gauge. Do you know the stock/default string gauge/ set Ibanez use for this model? I want to use the same gauge so I won't adjust the action, and trem profile. thanks in advance for those who will reply!
Old 10-21-2008, 03:16 AM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Stock set on Ibanez guitars is D'Addario EXL120 009-042.
'87
lower strings, neck relief, string gauges
Am I the only one that thinks DR Strings uses colors to cover poor quality strings? Clonetool Tech: Setup, Repairs and Mods 37 07-19-2007 03:58 PM
Help please! Strings choke on intonation screws TripleFan Tech: Setup, Repairs and Mods 16 08-16-2006 04:41 PM
7 strings, 8 strings...nah, 11 strings! Mikael Jurman Other 7-string Guitars 52 12-18-2005 01:34 AM
Can I adjust the intonation without the intonation tools? - cowcowcow Tech: Setup, Repairs and Mods 3 01-15-2002 04:11 PM
7 strings? - I'm running out of strings 1 1 Dragon 2 2 2 JEM and Universe Guitars 7 03-13-2001 12:36 PM
