Old 08-04-2007, 12:21 AM
Obfuscolios  is offline
Posts: 56  -  iTrader: (0)
Solder Tips?
After finishing the fretboard cleanup of my 3120, I plug her in to find out that the last upward position of the 5-way switch makes no sound, Dang! I take off the rear plastic guard to find that a small purple/blue (i'm color blind) wire came loose from the switch. After testing it, I found that it works fine when touched to the solder lump the other wires are secured by. So here's my question, how hard is it to strip back a little bit of the wire covering and solder it back in place?
-MikE
Old 08-04-2007, 01:57 AM
satchboogeyman  is offline
Posts: 343  -  iTrader: (1)
Re: Solder Tips?
Its easy. Buy a solder gun and some resin core solder and practice on an old circuit board or practice soldering wires together. Then check your solder joint with a volt meter. Check out the seymour duncan website and you can watch some vids of him soldering some pickups.
Old 08-04-2007, 06:15 AM
hydrahead  is offline
Posts: 23  -  iTrader: (1)
Re: Solder Tips?
The two hardest parts about soldering are: scrapping off the old solder and waiting for the iron to heat up the part.
I recommend 60/40 resin core solder. And I use a $15 hardware store soldering iron. Follow the instructions that come with the iron.
Here's the SD link http://www.seymourduncan.com/support...all_a_pu.shtml
Old 08-04-2007, 10:18 PM
Re: Solder Tips?
Thanks for the replies!
After doing a little research, I've got one more question to ask before I do the repair. I went down to Radioshack to look at the solder irons, and it turns out that there are several different versions with different wattages attributed to them. While I know that the wattage translates to warmup time and overall heat (at least that's what i was told), I was wondering which is sufficient for working on the guitar? I don't want to use too much heat and mess up something else when I do the repair.
Thanks,
-Mike
Old 08-05-2007, 06:12 PM
ryanb  is offline
Posts: 1,413  -  iTrader: (0)
Re: Solder Tips?
25-40 watts is plenty. If you are just doing control wiring, I would suggest staying in the 25-30 watt range.
Of course, IMO Radio Shack irons are crap. Go find a Weller iron at your local hardware store instead and it will work much better and last much longer.
Old 08-07-2007, 06:27 AM
Re: Solder Tips?
The Weller standard duty 25watt is what I use and it gets the job done.
Old 01-19-2008, 10:55 AM
wjs1820  is offline
Posts: 27  -  iTrader: (0)
Re: Solder Tips?
It's important to heat the wire and contact point with the iron so that it draws the solder into the connection. You dont want to heat the solder on the iron and try to drip it on the connection! This will cause a poor connection and will probably fail later.
Old 01-19-2008, 03:18 PM
shotgunlew  is offline
Posts: 80  -  iTrader: (0)
Re: Solder Tips?
I always use silver solder, seems to get the best connection, jus my 2Cents
Old 01-19-2008, 05:03 PM
Lefty Robb  is offline
Posts: 4,929  -  iTrader: (11)
Re: Solder Tips?
What ever you do, don't buy that ColdHeat gun, its a piece of $hit.
Old 02-02-2008, 05:20 PM
Oatman  is offline
Posts: 31  -  iTrader: (0)
Re: Solder Tips?
I was recently in the same boat. Just started teaching myself the ropes. I went with the switchable 15w - 30w radioshack iron. I like the lower setting for smaller parts. Plenty hot for the smaller joints, and less risk of heat damage. I like the 30W for those gigantic globs of solder grounding all the wires together on the pots. It will take FOREVER to melt through all that at only 15w, it's bad enough on 30w.
Also spring for the fanier clippy heat sink thingie. I started out with the el cheapo alligator clips and the heat sink that comes in the pack of solder probes/manipulators. They suck. Go for the nicer one with the red rubber handles (looks like a pointy tweezer).
Finally if I had it to do over again I would get this. In the end the difference in price would have been well worth it!!!
https://amptechtools.powweb.com/solder.htm
Weber VST is a great supplier.
His 63/37 quick set solder also rocks, but the regular radio shack stuff is good enough, just get the .022 diameter, and not the thicker stuff.
Featured Products
Reviewed by 3 members
Add your review!
Reviewed by 4 members
Add your review!
Reviewed by 5 members
Add your review!
Add your review!
Reviewed by 6 members
Add your review!
Add your review!
Add your review!
Add your review!
Reviewed by 8 members
Add your review!
Reviewed by 7 members
Add your review!
Add your review!
Add your review!
Add your review!
Add your review!
seymour duncan
mixing tips Artist Recording Studio 2 04-19-2004 10:51 AM
Double tracking rythm parts. Tips needed please Swirly Recording Studio 28 10-05-2003 01:10 AM
Hey Glen! USRG10 tips ! Jupiter Tech: Setup, Repairs and Mods 56 10-28-2002 09:11 AM
Need some soldering tips - Never done it before... Gresh Tech: Setup, Repairs and Mods 10 12-01-2001 12:34 AM
Tips on Changing Pickups? ashlock Tech: Setup, Repairs and Mods 6 04-22-2001 09:07 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
close
Sign up for free and join one of the largest communities of guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
Where do you live?
I agree to the website rules
