Old 05-13-2007, 06:03 PM
guitarman13  is offline
Posts: 388  -  iTrader: (0)
Soldering: What do I need?
The volume pot on my RG1570 needs replaced, and I also want to replace the pickups with better ones. So, I figure why not learn how to do solder now and save some money. I have some questions though; What wattage of soldering iron do I need to do this? And what type of solder to I need? Also, how should I practice soldering before I actually do it for real?
Old 05-13-2007, 07:28 PM
RG462  is offline
Posts: 507  -  iTrader: (0)
Re: Soldering: What do I need?
Its alot simpler than you are making it. Just buy any kind of craft soldering iron, doesn't have to be top of the line, and ask for electrical solder. It isn't that hard. All you need to do is heat the iron and melt the solder onto the joint between 2 wires, a wire and a pot, etc.
Old 05-13-2007, 08:19 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Wattage: 25 would be fine, 40 watts is plenty. Don't go higher for guitar electronics.
Solder: Rosin core 60/40. I use Radio Shack stuff, I think it's 0.50 diameter or something.
You should get some solder remover wick. You put it on top of the old blobs of solder and it soaks it up when heated with the iron. This makes the contact point clean ready for your next joint.
Buy a sponge for wiping the tip of the iron on after each joint you solder. If you search for "solder" on e-Bay you'll see all this stuff come up. Or if you go to an electronics store to buy, just ask them for all the stuff I mentioned.
Best thing you can do is search online for a soldering guide.
Old 05-13-2007, 08:40 PM
MadRyan  is offline
Posts: 246  -  iTrader: (3)
I like a 40w iron because it heats up the part a bit faster which allows you to solder the joint faster and remove the heat. IMO this makes for less heat absorbed by your part. On pots this is a big deal. I also tried something a bit different while swapping out a volume pot this morning before church. I ran a piece of solid copper 22ga from the ground on the pot to the body which I normally do, but in this case I soldered it to the body leaving enough to form a loop, to which I attached my pickup leads and ground. In this way I'm not repeatedly heating the blob of solder on the pot. It worked really slick.
Old 05-13-2007, 09:12 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
Yup, good stuff. Also, it's easier than you think.
Flux will help solder run smoother, but you probably don't need it.
Old 05-13-2007, 09:17 PM
Dee  is offline
I see your point. My current iron (a Draper 40w) heats up parts nice and quick. My previous iron was a pain in the ass sometimes, the wattage was too low and I couldn't solder as cleanly with it.
Thanks for the tip, btw.
Oh, and to guitarman13 -- take a pic of the wiring if you have a digital camera, get a close up just in case you forget where everything goes! But the least you can do is draw a diagram if you don't have a cam.
Old 05-14-2007, 10:48 AM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
I like to use solder paste as well - i coat the ends of the wires with solder (using the solder paste) before i make my connections. makes for a more solid connections.
I 'solder sucker' works well also, to get the old blobs off.
Old 05-14-2007, 03:59 PM
Dee  is offline
Solder sucker is something I forgot to mention.
Old 05-15-2007, 10:55 PM
neptoess  is offline
Posts: 303  -  iTrader: (0)
soldering is very easy. I self taught myself with no prior experience while installing Bill Lawrence humbuckers into 3 different guitars and rewiring another dozen or so. I use a big Weller 110/140W gun. The only tools you'll need is solder(i use the **** that came with my gun), an awe(little pokey thing to make holes in the terminals when desoldering, and pliers. As long as you're not changing anything besides one thing you just match up the wires and leave the rest alone. Just study the diagrams and you'll be fine.
Old 05-15-2007, 11:22 PM
MadRyan  is offline
Ya got a thing for the Lawrence Pups doncha...
I actually really liked the one I had in a Washburn N4 but IMO it's not my thing. I'm a firm believer in the fact that there's no one pickup that sounds great in everything.
Old 05-16-2007, 08:47 AM
neptoess  is offline
yea sorry about my obsessiveness for lawrences it's just that they are the grail pickups for me and i want other people to at least try them you kno? kinda like this board has a hardon for dimarzios
Need help soldering and wiring Eco Bridgfe Pickup Immediately! RG270L_Guy Pickups & wiring 1 09-23-2006 06:50 PM
The Soldering Iron Is Still Warm stormin" Other Ibanez Guitars (including Premiums) 3 06-03-2005 05:19 PM
coldheat soldering guns Jagermeistro Tech: Setup, Repairs and Mods 16 02-27-2005 11:30 PM
Need some soldering tips - Never done it before... Gresh Tech: Setup, Repairs and Mods 10 12-01-2001 01:34 AM
I suck at soldering!!! - any tips or instructions?...please? oop Tech: Setup, Repairs and Mods 10 06-04-2001 04:30 PM
