Old 10-15-2008, 12:08 AM
hotwax1989  is offline
Posts: 71  -  iTrader: (0)
Some quick questions about swapping to an Edge Pro..
I'm swapping my Edge 2 for an Edge Pro and I have a couple questions....
-I'm only getting the bridge and arm, nothing else, should I get new posts??
-Also should I replace the springs?
In case your wondering I do lots of Vai type whammy tricks, like fluttering, and I need sensitive tremolo tension. I know the point of contact is crucial, will my old posts and springs hold up?
Thanks
Old 10-15-2008, 07:13 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Re: Some quick questions about swapping to an Edge Pro..
you can try leaving the original posts and springs first. while you're at it, you'll help the posts doing their job by wrapping some teflon tape on their threads, to lock'em in place (not as stable as the stud locks, but better than nothing).
Old 10-16-2008, 09:10 PM
kaizzen  is offline
Posts: 54  -  iTrader: (0)
I had very wonky posts on a 2nd hand Ibanez.. The Teflon solution worked perfectly! It's been nearly a month now and everything is as good tuning wise on my other rg with an edge pro.. Perfect :-)
Nuno & Rich always have handy tips *2 thumbs up*
Old 10-22-2008, 06:03 PM
thanks you guys! i will try that. i guess teflon tape has many purposes in teh guitar world lol.
Old 09-20-2009, 10:12 AM
IBANEZRG320DXFMTG  is offline
Posts: 77  -  iTrader: (0)
where can i buy the teflon tape
Old 09-21-2009, 02:36 PM
andrewgosline  is offline
Posts: 312  -  iTrader: (0)
it's standard hardware store stuff. Used for taping threads that need to be watertight in plumbing.
edge, posts, pro, studs, tremolo
Rg 470 Bridge swapping questions superhairycamel Tech: Setup, Repairs and Mods 11 06-28-2006 11:30 PM
Lo-TRS II ??? - swapping with an Edge and more wulpul Archived Topics and Common Questions - GO HERE FIRST 16 01-07-2006 08:25 PM
quick questions viva Pickups & wiring 2 09-01-2003 03:08 AM
Two quick questions Sephiroth000 Pickups & wiring 5 01-27-2003 07:29 PM
2 questions - one quick one not so quick tagg 7 Other 7-string Guitars 3 01-22-2001 06:22 PM
