Go Back   Jemsite > Toolbox: Setup, Repairs and Mods > Tech: Setup, Repairs and Mods
Old 12-03-2006, 06:00 AM
aeromike aeromike is offline
Posts: 24  -  iTrader: (0)
speaker connections
hi, all. a simple question here, when connecting speakers in series or parallel does it change the actual tone or sound of the speakers/amp? or is it just simply of the Ohms sake?
cheers
mike
Old 01-21-2007, 02:06 AM
albee1952 albee1952 is offline
Posts: 719  -  iTrader: (2)
Re: speaker connections
changing the ohmage CAN change the tone of a tube amp as it will load it differently. Don't forget the math. 2 speakers in parallel will be half the impedance of 1(never mix speaker impedance in a cabinet). i.e. 2 8 ohm speakers in parallel=4 ohms. Speakers in series will double. i.e. 2 8 ohm speakers in series=16 ohms. Check your amp to see if it has a max or minimum load. A 16 ohm load will net less wattage from the amp than an 8 ohm or 4 ohm load.(unless there is an impedance switch to compensate).
Bookmarks
ohm load, ohm speaker, ohm speakers, tube amp
