Tech: Setup, Repairs and Mods
Sperzel locking tuners - how to use them?
08-17-2001, 11:38 PM
caprile
Posts: 1,619 - iTrader: (
Hey! I got a set of sperzerl
locking tuners
and have some doubts about how to use them:
1-how much string to cut?
2-how tight must the locks be?
3-my guitar has an angled headstock, and they come with 'staggered height' ie you don't need a
string tree
on a strat. does this have any effect?
4-can you get a set with equal height (i know some guitars come with them but i have not found a 6 in line replacement set)
thanks a lot in advance
caprile
Find all posts by caprile
08-18-2001, 03:58 AM
rickboot
Posts: 332 - iTrader: (
I have locking Sperzels on my
Parker Fly
. I love them.
To install strings:
1) Loosen the locking knob on the back of the tuner
2) Line up the string hole so it is parallel with the neck
3) Install the string at the bridge end first then pull the string through the post and pull it tight
4) Lock down the locking knob
5) Cut the string off at the post. You don't need any wraps around the post. That is why these tuners stay in tune better.
I haven't seen non-staggered versions of these tuners for sale. However, if your neck is angled AND you use the staggered tuners you should be fine. Not having the string tree will improve tuning stability.
Rick
rickboot
Find all posts by rickboot
08-18-2001, 04:43 AM
caprile
thanks man! should i put the highest on the low or high e? (the highest is just like the ones i have now)
thanks.
congrats on your fly, cool guitar!!
caprile
08-18-2001, 03:22 PM
Two hands31
Posts: 4,989 - iTrader: (
I also have a couple of questions:
1) *How much is a 6 in-line set? *
2) *How good are these for
alternate tunings
(i.e. switching tunings a lot)?
3) *How stable do they keep the tuning (i.e. Locking Nut-ish or better/worse)?
4) *How hard are they to install on a
Squire Strat
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
08-18-2001, 03:53 PM
caprile
i really don't know how much these cost, mine were a gift , check stewmac.com or warmoth.com. you should have no problem changing tunings because of the tuners, but i find that the strings get 'used' to a tuning and dont response very well to alternating (that's a really subjective opinion btw).
installing is really easy: they don't have a screw, but a a single pin that prevents rotation, since the pressure that holds it to the headstock comes from the hex in front of it. a lot of newer guitars have this system, an if they dont, all it takes is a little drilling, which doesn't have to be perfect since the tuner covers the hole.
if your guitar has the old screw system, the only problem would be the ugly holes left.
if you use the trem a lot, they don't do as good as a locking system, but with subtle or no bar use (like me) they're great
caprile
08-18-2001, 05:09 PM
Two hands31
Thanx! *That's exactly what I needed to know. *Mine's got the hex system, so no trouble there.
Two hands31
09-05-2001, 03:09 AM
AJofATTICA
Posts: 15 - iTrader: (
I consider myself quite knowledgeable regarding Sperzels....considering 3 of my 5 guitars have them.
*You only need the strings to be just a bit longer than the post. No extra winding needed. Pull the string through.....tighten the knob down and cut the excess string off. Tune to pitch.....stretch them......retune. Viola.....
As far as 6 inline sets.....they do make them. Check Musicians Friend. Pricing is right around $50 for a set of either the 6 inline set or 3+3 style set.
They are easy to install and quite a good invention. I have them on my Parker, Carvin, *and installed them on a
Gibson Les Paul
. *I am thinking of buying some and replacing the stock locking tuners on my PRS with Sperzels....because Sperzels work better IMO. *I may even think about putting them on my Universe, but I doubt it. Too much work! lol
Hope that helps.....
A.J.
AJofATTICA
Visit AJofATTICA's homepage!
Find all posts by AJofATTICA
09-06-2001, 05:53 PM
caprile
thanks aj! but what i meant by 6 in line is 6 in line with equal height, for an angled headstock. My set is 6 in line but is staggered. I installed them and they work fine, just doesn't look quite right.
caprile
09-07-2001, 12:09 AM
AJofATTICA
Oh ok! Usually the 6 inline(staggered) are meant for guitars without a angled headstock, but obviously they work fine!
Good to see people opening up to them.....they are awesome tuners! I swear by them! I love my Universe....but definitely prefer locking tuners to
locking nuts
myself.
Good luck!
A.J.
AJofATTICA
alternate tuning
alternate tunings
gibson les paul
les paul
locking nut
locking nuts
locking tuners
parker fly
squire strat
string tree
why doesn't dave weiner use a locking nut?
can a bottom mount R2 locking nut be used as a top mount?
jem7dbk locking stud?
what locking tuners fit agile 2000
drop D with fine tuners?
07:12 AM
