Tech: Setup, Repairs and Mods
Spring for fine tuner?
05-20-2006, 10:17 PM
Kemono
Posts: 157 - iTrader: (
My fine tuner on the high E quit working after I changed strings.
Bridge is Edge Pro (I think) it's an rg8670.
What do I need to do to fix this?
Kemono
Visit Kemono's homepage!
Find all posts by Kemono
05-20-2006, 11:12 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
Re: Spring for fine tuner?
You mean the small metal plate that holds the fine tuner bars up? If it is what you mean you could probably just bend it up a little to get the springing action back into it.
brothersnowgone
05-21-2006, 12:43 AM
Kemono
Yeah, I'm not sure what happened to that. It isn't working. I guess it's the peice of metal is bent or broken. I'm taking it in.
Kemono
how to use locking tuner
how do you use fine tuners edge 3
fine tuner drop d how
how to run tuner out of signal
is it ok to use only one spring with a trem claw
Adding spring reverb to an amp
bduersch
Gear and Equipment
09:05 PM
Best way to send a clean signal to tuner??
ChrisReedSmith
Gear and Equipment
12:26 PM
Which tuner?
Drache713
Gear and Equipment
08:26 PM
Trouble w/ Arm Holder Spring in Lo-Pro Edge - Help!
elfstones
03:25 PM
Rack tuner - can I put a tuner in the effects loop? - I coul
djrjems
Gear and Equipment
10:55 PM
09:18 AM
