Old 08-06-2007, 09:46 AM
jthompso  is offline
Posts: 11  -  iTrader: (0)
Springs/tremelo question!!
Hi guys,
I put some heavier gauge strings on my 7620 and I needed to add another spring to set the bridge level properly, but there are only holes for 3 springs in the bridge. I have taken one of the screws out that fastens the plate that fastens the spring tips into the bridge and placed the 4th spring tip into that screw hole and it seems to be ok. Is it true that the bridge is only designed to accept 3 springs? Also is it ok to place the 4th spring in one of the screw holes?
Cheers
Old 08-06-2007, 10:33 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Re: Springs/tremelo question!!
The answer to both of your questions is Yes and Yes. Technically, the block can accept up to 5 springs if you count both screw holes (that sounded dirty, LOL). Nevertheless, you should be fine using the screw holes to accept extra springs.
Jimmy
Old 08-07-2007, 01:04 AM
jthompso  is offline
Jimmy
Thanks for your response! Ill just keep it as is then. I was just concerned that maybe over time the spring would wear down and damage the thread of the screw hole!
gauge strings
MR HOSONO - QUICK QUESTION User010101 Comments to Ibanez 1 07-18-2007 12:36 PM
Quick question on 2x12s tobe Gear and Equipment 4 03-18-2005 08:21 PM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 03:41 PM
Bad horsie 2 question and Amp Question snorkthesick Gear and Equipment 1 04-11-2004 05:56 PM
WARNING: Stupid Floyd Question Ahead! Ugoyin Tech: Setup, Repairs and Mods 8 01-07-2004 08:56 PM
