That's an easy one
The 17th is high right in that spot, seen this before. Give it a good tap with a hammer first to make sure it's set, if it still buzzes spot it down with a file or my new fav, popsicle stick with 240 on one side and 400 on the other. That you can do with the strings on, whammy depressed all the way. Just take a little off and check, more off if needed till it stops buzzin! Make sure you're taking it off the right spot on the fret or you may get a buzz on the B at the 17th! :biggrin:
