Old 12-01-2008, 04:46 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
strange fret occurence
my 16th fret on the G string of my rg2550z, when the note is hit, instantly turns into a pinch harmonic.
the note just instantly goes an octave above, as if you were hitting the string over the pickup or doing a pinch harmonic.
i've raised the bridge really high, doesn't solve the problem. i've adjusted the neck a few times as well. i'm not really sure how to measure neck relief, but it's not flat. i'd say it's got a "good" amount of curve in it, but then again i don't know what to check it against.
it's only this fret on this string. i'm guessing it's something to do with the frets. it also happens when you bend up on the 14th fret on the G to the 16th fret.
EDIT:
found out it also happens to a lesser degree bending the 11th fret on the B string up to the 12th fret.
Old 12-01-2008, 06:25 AM
Homebake  is offline
Re: strange fret occurence
i fixed up the intonation and the problem is gone :S
action, fret, harmonic, pinch, rg2550z
Help, action high at 5th fret, low at 19th fret Rachmaninoff Tech: Setup, Repairs and Mods 3 06-06-2008 12:03 PM
Got a new guitar, but its got fret buzz on one string at one fret how to fix? ibanezcollector Tech: Setup, Repairs and Mods 6 11-25-2006 07:43 PM
If I'm getting fret-rattle from the 12th to the 18th fret...? Superuser Tech: Setup, Repairs and Mods 0 02-03-2006 01:11 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 05:35 AM
Strange fret buzz - Only at 16th fret, G string carlos seo Tech: Setup, Repairs and Mods 3 02-07-2001 12:12 AM
