The P3 I just got is starting to concern me....
I had a buzz at g string 1st fret. So I tweak the
truss rod. Ok? No buzz there now.
Action seems high. So I lower the trem posts( set screws and all). High side goes as low as it will go. Still too high.
At this point I discover that if you loosen the set screw more, you can lower the posts more. Right?
So, I loosen the set screws as much as they go. Posts down as far as poss...
Hmmmm...still to high.
Dont get me wrong..the action is playable,improvable, but not that bad.....but surely it should go as far down as to have then rattle?????
Any ideas???
Another thing is that the pups wont go further down. They are not too high, but its strange it doesnt hide more. Is it cause they are direct mounted?
Thanks for your help
Julio
<he who is concerned, cause he thinks he could have a dodgy neck
