Old 03-17-2005, 07:00 PM
Onizuka  is offline
Posts: 203  -  iTrader: (0)
String changing question
Hi, when i changed my strings, the trem seems locked, and its locked in the position as if u had pulled it all the way back. What do I do? I havent put all the strings on yet though.
Hope u know what i mean..
Regards
Thomas
Old 03-17-2005, 11:53 PM
buddroyce  is offline
Re: String changing question
Once you put on all the strings, the string tension *SHOULD* pull the trem up. In the future you may want to change strings with a *fuzzy stick* or do what I do and push down on the trem bar once you have all the strings on and are about to tune to pitch.
Old 03-18-2005, 01:14 AM
moro  is offline
Posts: 623  -  iTrader: (2)
So the bridge is wedged in some how and stuck? What happens when you push down on the bar?
In the future, you may try changing your strings one at a time. It's much easier that way, imo.
Old 03-18-2005, 03:49 AM
Onizuka  is offline
I can move it with the bar. I'll see what happens when i have all the strings on, next time i will try one and one string, thanks for ur tips (I love this BB)
Old 03-19-2005, 07:26 AM
Onizuka  is offline
Sorry but i'm kinda new to this.
When u tune one string, that string goes out of tune when u tune other ones, and that goes for all the strings. Any tips?
Old 03-19-2005, 08:08 AM
Jem7RB MK  is offline
Posts: 2,341  -  iTrader: (20)
Keep tuning up until all 6(7/ strings are back in tune, Stretch them and repeat
Rob
Old 03-19-2005, 08:27 AM
Onizuka  is offline
how do u stretch?
Old 03-20-2005, 11:34 AM
MicJustMic  is offline
Posts: 930  -  iTrader: (0)
Just grab each one and pull it out from the guitar. (Not too hard)
Make sure the nut is UN-LOCKED.
Tune all strings to pitch, grab your low E (or B on a 7 string) and pull it away from the guitar a bit, tug it back and forth a few times . . . it will drop flat . . . tune it to pitch again and repeat until you get almost no drop in pitch when you tug on it.
Go to the next string, repeat . . .
Once you have all stings stretched do a final tuning then clamp the nut, do a few dives and pulls, flutter, abuse it a bit, basically . . . then fine tune.
Abuse the bar again, bend some strings, play a bit, fine tune again.
You should be good to go, if you're way out of tune, unlock the nut and do it again, you haven't stretched them enough.
Don't be too tentative about it, they can take quite a bit of abuse, just don't try to pull them more than a few cm from the body (especially the high E) or you could break the string.
Mic
Old 03-20-2005, 11:37 AM
Also, it's usually much easier to change strings one at a time with a floating bridge, that way the other strings will keep the bridge close to level instead of dropping down into the body.
Mic
Old 03-20-2005, 03:12 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
Onizuka,
If the new strings are the same gage as the old ones, then once you bring all the strings to the correct pitch, the tremolo will sit in the right position.
It's a bit of a pain in the but, but once you get it set, the next time change one string at a time like a few other people have suggested. This way the trem has a good amount of tension both ways at all times. Better for the neck too. No radical tension changes. The trem is "floating", meaning that there is a balance of tension from the strings, and the springs. You remove or change that tension and the tremolo positioning will change.
Old 03-21-2005, 03:18 AM
Onizuka  is offline
Take it out of the guitar, u mean on the back, like under the backplate where they come out? U just stretch them there?
And if the trem isnt in the right place?
I'll just adjust the springs under the backplate?
Old 03-21-2005, 03:33 AM
moro  is offline
No, on the front. The way I do it, I put the guitar face up on my lap, hook my first and second fingers under the middle of a string (around the 12th fret), and pull straight up, away from the face of the guitar. Then, while keeping tension on the string, I slide my hand 1/3 of the way toward the bridge, then 1/3 of the way toward the nut.
Yes. There's a metal plate with hooks on the end (the "claw") that the springs are attached to. The claw is anchored to the body with two screws. Just tighten or loosen the screws.
Old 03-21-2005, 03:53 AM
Onizuka  is offline
Then u let go of the string, retune all strings again, and then repeat this process?
Old 03-21-2005, 04:03 AM
moro  is offline
While I'm stretching the strings, I find that it's too much work to tune the entire guitar up to pitch. Get all the strings roughly up to pitch, then stretch one string at a time. Stretch the string, tune it up, stretch it again, and keep repeating until the string doesn't go out of tune after you stretch it.
Repeat for all the strings, *then* tune the entire guitar.
Old 03-21-2005, 07:38 AM
Onizuka  is offline
Ok, i'm giving it a try, thanks for the tips
floating bridges, string tension
Lost STRING LOCK BLOCK : need a replacement urgently Incommunicado Tech: Setup, Repairs and Mods 10 09-26-2011 07:29 AM
String Guage Question razor7 Tech: Setup, Repairs and Mods 31 04-18-2003 04:23 PM
7 string tunigs christianc Other 7-string Guitars 20 10-11-2002 02:18 PM
Changing Regular 6 String Acoustic Into Baritone Westmushokfan Other 6-string Guitars (non-Ibanez brand) 2 09-10-2002 04:27 AM
Changing string gauges - What's to be setup again ? Wicked Blade Tech: Setup, Repairs and Mods 2 04-22-2001 02:21 PM
