Tech: Setup, Repairs and Mods
String height way too high
01-30-2006, 10:00 PM
typedeaf
Posts: 58 - iTrader: (
Hey guys. I cleaned off my new (used) UV777Bk frets will steel wool, lem-oiled my fretboard, and slapped on some new strings. Now to my horror I have two new issues.
1) With a normal set of 10's the trem floats way to far forward and the
claw screws
are really in far already. The claw hook is less than a quarter inch from the wood. Thats pretty close, right?
2) bigger issue. The strings are up pretty high off the fretboard. At the 12th fret, the top of the bottom of the low B string is at about 3mm. Thats my measurement with a crappy paper ruler i printed out. Regardless, on my LNG, the low E is 2 mm off the fret at the 12th fret using the same ruler. So the UV is at least a mm higher and feels like even more. Hell, my Jackson's low E sits on the 1mm mark at the 24th fret! The trem "studs" are all the way down, so is this a
truss rod adjustment
or something worse?
Thank for the help in advance.
10:12 PM
typedeaf
Find all posts by typedeaf
01-30-2006, 10:07 PM
ChopTart
Posts: 1,390 - iTrader: (
Re: String height way too high
I've had a similar problem with my action and i want this answered also.
As for the trem floating, try arranging the three springs in an arrow formation rather than parallel:
\ | / rather than | | |
If that doesn't do it, try adding another spring (which you probably shouldn't have to do for 10s)
ChopTart
Find all posts by ChopTart
01-30-2006, 10:11 PM
ET Guitars
Posts: 369 - iTrader: (
1) Add another spring if you can. This should bring the trem more level and give some adjustment with the screws. ie. the
string tension
is higher than your spring counterbalancing tension currently.
2) Once you fix 1), then 2) should better. Then you need to re-check your neck bow (
truss rod
tension). I think you meant 3-4 mm? 4cm is like nearly 2inches? If still no good, you may need to look at the neck alignments starting in the neck pocket.
ET Guitars
Visit ET Guitars's homepage!
Find all posts by ET Guitars
Ant1981
Posts: 2,181 - iTrader: (
lower it
Ant1981
Find all posts by Ant1981
01-30-2006, 10:13 PM
typedeaf
ChopTart
Thanks. I will check my LNG or Jackson and see how the springs are. I hate taking screws out because it seems like after so many times, the hole they go in will be stripped. Is this logical? I will let you know if it fixes the problem.
typedeaf
01-30-2006, 10:14 PM
Ant1981
I want a LNG, its not fair!
Ant1981
01-30-2006, 11:10 PM
typedeaf
changed the spring alignment, still cant get to E. I guess I am cutting off my brand new strings and slapping on some 9 guage. Man, what a waste of money. Anything else I should try?
typedeaf
01-30-2006, 11:13 PM
Posts: 19,350 - iTrader: (
A $2 spring.
01-30-2006, 11:20 PM
typedeaf
A $2 spring.
You mean 2 $2 springs, right? Do you think I shold use 9's though and add the springs? Is 10's just to much resistance? I am thinking about just dropping it off to have to set up tomorrow anyway. Its beyond my skill to get this thing setup properly.
typedeaf
David McCarroll
Posts: 2,049 - iTrader: (
typedeaf
since you have seven strings (more tension) on a UV, the spring setting on your LNG is irrelevant - try adding a spring. Check the
neck bow
- if you are putting thicker strings on the guitar the 'rod may need adjustment (don't touch if you don't understand - seriously!!!!) - you can screw the posts down to lower the whole bridge without loosening the strings (check for locking posts though) - if you took the neck off to clean the frets, are you sure you didn't lose a shim when you put it back on?
Check Ibanezrules tech pages - go through Rich's stuff carefully and methodically, he explains a lot about setting up guitars WITH PICTURES which may point out to you where things may have gone astray, but I'd definitely start with an extra spring and work through from there. If you don't really know what you're doing, get a luthier to do a setup - money very well spent IMHO!!!
David McCarroll
Find all posts by David McCarroll
01-31-2006, 08:37 PM
ryanb
Posts: 1,457 - iTrader: (
It probably had 9s on it before. When you put the 10s on it, the tension of the two springs (even with the claw all the way in) isn't enough to balance that out. You need to add an additional spring so you have three. Then string up your 10s to pitch and adjust it until you have the trem sitting level again. At that point, check the action again. You may find the action is fine with the bridge sitting level. If not, you probably need a truss
rod adjustment
. (You probably need one anyway if you have changed from 9s to 10s.) But there is no reason to cut off the new 10s and switch to 9s. If you want 10s, use the 10s and get it set up right.
ryanb
Find all posts by ryanb
01-31-2006, 10:45 PM
kennydoe
Posts: 3,416 - iTrader: (
If there were 9s on there and you switched to 10s, of course you're going to have trem issues.
Sounds like you just need a good setup.
You don't need another spring and you don't need to take the 10s off. It's something that can be dealt with by a professional in about 15 minutes.
There are a TON of Jemsiters in Houston who can help you. Look 'em up.
~K
PS: I have used .10s on my UV with 3 springs for the last 5 years or so without one single problem. They're on | | | , but i don't think it makes that much of a difference in this case.
kennydoe
Visit kennydoe's homepage!
Find all posts by kennydoe
02-01-2006, 01:40 AM
nightfiend14
Posts: 1,005 - iTrader: (
Don't cut the strings off your guitar, unwind them. It's bad for the neck to just cut them all quickly.
nightfiend14
Find all posts by nightfiend14
02-02-2006, 08:10 AM
Eddy_mc
Posts: 8 - iTrader: (
Have you ever thought that your springs might be shot, springs don't have an indefinite life, they could be stretched.
Eddy
Eddy_mc
Find all posts by Eddy_mc
02-05-2006, 07:22 PM
typedeaf
The guitar is not many years old, but I guess the springs could be shot. Regardless, new discovery: you cant add more than 3 springs. there are only 3 spring holes. doh! guess i am going to just screw the claw in further for now.
typedeaf
claw screws
neck bow
rod adjustment
steel wool
string tension
truss rod
+bias +"when playing" +"high volumes"
guitar playing talent show high school
how to get string height on strat low
where to buy guitar string sin southampton
use a .016 for the 2nd string?
Can you individually adjust the height of a string on a Lo Pro and Edge tremolo?
Econ
09:26 PM
High E String breaking!
Adagio_777
09:08 AM
High E string fine tuner will not sharpen on JS1000 Help!!!!
mikeyCOA
07:08 PM
can't get rid of string buzz on JS10th
SilverSurfer2
32
01-13-2003
09:25 AM
String breakage - High E-string is always breaking at the br
larsmars
04:35 AM
12:39 PM
