Old 11-25-2008, 02:13 PM
SRVoodoo  is offline
Posts: 256  -  iTrader: (0)
String lock Screws for Edge-Pro
Does anyone know if the String lock screws from a Lo-Pro will fit an Edge-Pro?
or where I can get Edge-Pro screws that are just a bit longer?
The idea here is to be able to use the Lo-Pro Intonation tool on the Edge-Pro Bridge.
Old 11-25-2008, 02:43 PM
chaos731  is offline
Posts: 489  -  iTrader: (6)
Re: String lock Screws for Edge-Pro
hmmm...paging Dr. Rich...Dr. Rich, you have a telephone call at the front desk.
Old 11-25-2008, 05:05 PM
Rich  is offline
I've been trying for a year to get them to lengthen them. I've thought about having a batch made myself but would much rather just buy a factory part [and have them installed on all future EP's]
Old 11-25-2008, 05:19 PM
SRVoodoo  is offline
so the screws from the lo-pro don't fit then?
...p.s. I do NOT have a lo-pro to try the swap myself but I would order the
screws if they fit. Otherwise I might just take a ride to Home Depot with one of my EP screws
& see if they have something that would work.
Old 11-25-2008, 05:28 PM
Rich  is offline
way shorter.
The bolt is easy to get, it has to have the tip machined.
Old 11-25-2008, 05:46 PM
SRVoodoo  is offline
Yeah, those machined tips.
I wondered if it was actually "mechanicly neccessary" or not.
Old 11-25-2008, 06:02 PM
Rich  is offline
People have used regular non machined bolts, I've replaced them in used guitars. It'll work, it's just not the way it's supposed to be. The back of the lock block is formed female to accept the machined tip.
Old 11-25-2008, 10:33 PM
SRVoodoo  is offline
I guess the machined tip going into the female block keeps things in proper alignment.
My only idea then is to get longer bolts, grind them down on the bench grinder, & use a tap & dye kit to fix the end threads.
Old 12-18-2008, 05:02 PM
SRVoodoo  is offline
Hi Rich, can you tell me the dimentions of the bolts cuz I have no way of measuring
them. I'm planning to buy a tap & die set so I can "hand machine" my own bolts.
Thanks!
Mike
p.s. there was no info on Ibanez.com
Old 12-20-2008, 04:20 PM
TKO Ken  is offline
Posts: 157  -  iTrader: (0)
that's what I would do, I can't see why it wouldn't work.
Old 12-20-2008, 04:25 PM
TKO Ken  is offline
Thanks!
Mike
I would pull one of the screws out, head to your local hardware store and find a nut that fits. Get a tap and die of the nut thred size and you're good to go.
Old 12-20-2008, 04:30 PM
TKO Ken  is offline
Thanks!
Mike
oh yeah, more than likely it's metric.
Old 12-20-2008, 06:27 PM
SRVoodoo  is offline
yeah, that's what I'll have to do....after the holidays perhaps.
I think Home Depot has a way to measure the threads, then I just need the Die set for that particular size, turn on the bench grinder & go-to-town on 'em
Old 12-21-2008, 02:55 PM
Rich  is offline
They're just M4's.
Old 12-21-2008, 02:59 PM
SRVoodoo  is offline
Please forgive me my ingorance but does that mean 4mm?
Originally Posted by Rich View Post
They're just M4's.
edge pro screws, lo pro screws
edge lo pro - how to insert the string lock blocks new_breed Tech: Setup, Repairs and Mods 11 02-02-2011 01:16 AM
Edge III Problem (String Block Screws) magic_golem Tech: Setup, Repairs and Mods 1 03-06-2008 10:02 AM
Lo Pro parts - String Lock Screws needed GazTop Tech: Setup, Repairs and Mods 2 11-09-2006 08:52 PM
String lock block for Edge trem satchman Tech: Setup, Repairs and Mods 1 07-11-2006 01:38 AM
I lost one of the locking nut lock screws from my RG HELP!!! Aussie_520QS Tech: Setup, Repairs and Mods 0 07-13-2002 04:44 AM
