Old 08-31-2007, 10:20 AM
Benson  is offline
Posts: 109  -  iTrader: (0)
String mute device
I'd like to be able to mute my open strings from ringing out when playing certain stuff, an approach often used by shredders, funk rhythm players and bass players too I believe.
I know Michael Angelo Batio sells a mechanical string mute which puts a movable foam pad on the strings but its a bit drastic and expensive for several guitars. I've been experimenting with various sized elastic hair bands from my wife but nothing so far has worked well.
Does anyone know anything that's effective ?
Tony
Old 08-31-2007, 10:32 AM
alex10  is offline
Posts: 698  -  iTrader: (1)
Re: String mute device
A sock works well.
Old 08-31-2007, 10:46 AM
studentofshred  is offline
Posts: 145  -  iTrader: (0)
I just use athletic wrist bands. Roll it back behind the nut when your not using it, and roll it down when you need it. I'm not sure if I can explain this well, but you'll need to fold it half to get a good dampening effect It only gets to be annoying when you go for a string change.
Old 08-31-2007, 11:21 AM
Benson  is offline
All good suggestions, but a sock is impractical during gigs and a wrist band is a bit too bulky. I've seen Guthrie Govan use what looks like an elasticised bootlace which he rolls on and off depending on whether he needs it.
Tony
Old 08-31-2007, 11:23 AM
markg5150  is offline
Posts: 2,361  -  iTrader: (2)
Guthrie uses a hair band - similar, cheap & effective
angelo batio, guthrie govan, michael angelo batio
Eight string finished..... Serratus Other 7-string Guitars 62 10-05-2006 05:38 PM
String bending (low action) blackpuppets Tech: Setup, Repairs and Mods 12 10-27-2005 03:56 PM
Bass pickups in 7 string and 7 string single coil demo juiceofvenus Pickups & wiring 4 08-29-2003 03:54 PM
D string refuses to intonate illumina Tech: Setup, Repairs and Mods 0 08-01-2003 03:32 PM
Picking up the slack... - ...on that low string mechanyx Tech: Setup, Repairs and Mods 7 03-31-2002 02:23 AM
