Old 10-11-2004, 06:49 AM
Benson  is offline
Posts: 109  -  iTrader: (0)
String retaining bar on headstock
The headstock string retaining bar (behind the nut) on my Jems seems to be set at different heights, is there a standard setting based on string height ?
Old 10-11-2004, 08:09 AM
dex  is offline
Posts: 1,972  -  iTrader: (3)
If you want to minimise how sharp the strings are pulled when you lock the pressure pads - make sure that the retaining bar is set low enough to hold the string down all the way across the nut.
There's no point having it lower than that and having it higher would make the bar redundant.
ilia
Old 10-11-2004, 08:19 AM
Benson  is offline
ah, that makes sense, ta.
Old 10-11-2004, 10:27 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
if the truss-rod cover sits on the way and keeps the retainer-bar to be set low enough, pull it out.
retaining bar, string retaining bar
