Old 11-08-2007, 01:24 PM
Zelman  is offline
Posts: 21  -  iTrader: (0)
Strings for Whole Step Down (DGCFAd)
Hi!
I've got a question.
I am currently using Ernie Ball 10-46 Regular Slinky strings in standard tuning.
I want to down-tune my guitar whole step down to DGCFAd.
My questions is:
What strings should I use to get the same string tension in new tuning?
I am thinking about:
Ernie Ball Beefy Slinky (11-15-22-30-42-54) <-- they have description "Optimal for Detuning"
and Ernie Ball Power Slinky (11-14-18-28-38-48 )
Please, help me
Adam
Old 11-08-2007, 02:38 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: Strings for Whole Step Down (DGCFAd)
Hey Adam.
Are you wanting to buy the strings as a set or as singles? You are better off buying them as singles, this way you can achieve graduated tension across the strings, but it can be slightly more expensive. Also, the only string manufacturers that supply singles are Ernie Ball and D'Addario, to my knowledge, so you may be limited in your purchasing options.
But anyway... a regular 10-46 set tuned to standard will give you approx. 103.59 pounds of total tension. The Beefy Slinky from Ernie Ball is a strange set. The 22 gauge from this set gives you over 22 pounds of tension. This is a huge jump from the previous string, (15) which is only around 16.25. The 22 is also 3 pounds HEAVIER than the next heaviest string (30) at 19.87 pounds. "Optimal for detuning"? I don't think so, Ernie! Replace that 22 with a 20 (18.2 pounds) and you'll be closer to a better feeling set of strings. The rest of the strings are OK, but I'd be tempted to replace the 54 with a 56.
Ernie Ball Beefy Slinky 11-54
D: .011" = 15.57
A: .015" = 16.25
F: .022" = 22.03
C: .030" = 19.87
G: .042" = 20.89
D: .054" = 19.19
Total = 113.8 pounds
11-56 Custom Set (from singles)
D: .011" = 15.57
A: .015" = 16.25
F: .020" = 18.20
C: .030" = 19.87
G: .042" = 20.89
D: .056" = 20.92
Total = 111.7 pounds
As you can see, the custom set is superior in terms of graduated / progressive tension. String manufacturers are stupid.
As for the Power Slinky set, I wouldn't even go there. Look:
Ernie Ball Power Slinky 11-48
D: .011" = 15.57
A: .014" = 14.16
F: .018" = 14.74
C: .028" = 16.91
G: .038" = 17.13
D: .048" = 15.03
Total = 93.54 pounds
Atrocious. This set would feel and sound terrible. There is nowhere near enough tension on those strings, and tension is all over the place anyway. There would be more tension on the high E than the low E!
Old 11-08-2007, 02:49 PM
Roland  is offline
Posts: 617  -  iTrader: (0)
Wildly different from person-to-person preference: I myself use gauges 0095-13-18w-24-34-48. Rather light top, with quite a progression in tension to the low-end. Those are single-strings. I suspect you'd want a bit more tension... check the D'Addario tensionchart.
http://www.daddario.com/Resources/JD...sion_chart.pdf
EDIT: and a plus-one to what Dee said.
Old 11-09-2007, 04:11 AM
Zelman  is offline
Hey!
Thanx for quick and great reply
What do you think about this strings:
http://www.daddario.com/DADProdDetai...D=1&Class=AABA
D'Addario EXL116 (11-14-18-30-42-52) ??
I have to buy a set of strings, because buying single strings in my country (Poland) might be difficult.
Old 11-09-2007, 12:07 PM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Zelman,
Check out the thread in the Gear & Equipment forum about tuning to Drop C, you'll probably be OK with 11s or 12s.
'87
Old 11-09-2007, 01:54 PM
Roland  is offline
Originally Posted by Zelman View Post
Hey!
At first glance, it looks kind of okay. Too heavy of an A- and D-string, but I guess this'll suffice. However, if you can, singlestrings are the best way to go if you compare sets head-to-head. I realise that getting a hold of them can be a bit hard... Try http://saitenkatalog.de!
addario exl, ernie ball, string tension
Your string guages are wrong! Dino Gear and Equipment 238 05-05-2008 07:34 PM
D'addario EKXL120 Tremolo Strings W0MB13 Gear and Equipment 3 09-30-2006 10:50 AM
Strings for drop C tuning Wound Other 7-string Guitars 12 10-28-2004 01:54 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Other 6-string Guitars (non-Ibanez brand) 10 05-09-2001 02:20 AM
7 strings? - I'm running out of strings 1 1 Dragon 2 2 2 JEM and Universe Guitars 7 03-13-2001 12:36 PM
