Tech: Setup, Repairs and Mods
strings tension
01-07-2008, 10:44 AM
xklusivly4u
Posts: 392 - iTrader: (
strings tension
This might be a silly question. Do you guys have ever experienced that strings tension is different from one guitar to another? I feel that
string tension
on my RG is stiffer than on my JEM. If that’s not normal, is there a way to fix that? And what is the best low action you guys aim for?
11:01 AM
. Reason: xx
xklusivly4u
Find all posts by xklusivly4u
01-07-2008, 08:42 PM
shogun
Posts: 1,525 - iTrader: (
Re: strings tension
i experience this all the time.
shogun
Visit shogun's homepage!
Find all posts by shogun
shogun
Re: strings tension
quite a few variables involved
shogun
01-07-2008, 09:23 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Re: strings tension
I agree. I have all different kinds of guitars here set up with all different kinds of tunings and
string gauges
, and they all seem to have their own feel.
What I've noticed is that I really prefer guitars with 11's in drop C, but some thinner guitars have a "looser" feel, and they feel tighter in standard D.
It's kind of a guessing game with guitars. Kind of like women, you have to just accept them the way they are, and try not to worry about their flaws.
jaxadam
Find all posts by jaxadam
01-08-2008, 06:10 AM
xklusivly4u
Re: strings tension
jaxadam
xklusivly4u
01-08-2008, 10:32 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: strings tension
It also depends on the strings you're using. Try replacing the set and see how they feel.
Jimmy
jb4674
Find all posts by jb4674
01-08-2008, 11:09 AM
Myst and rain
Posts: 3,474 - iTrader: (
Re: strings tension
Having said that many factors, which differ from guitar to guitar, determine the tension, I've recently heard that the screws on top of the tuners, can be used to alter the string tension. I think they regulate the stiffness of the poles you stick the strings in. That's one thing I've heard. You can see the holes in which the screws I mentioned are, in the pic below.
That's something that might help.
Alwin
Myst and rain
Find all posts by Myst and rain
01-08-2008, 12:38 PM
xklusivly4u
Re: strings tension
Myst and rain, I noticed those screws but didn’t know what they are used for. I suppose loosening them will reduce the string tension. I will play around with them and see how it goes. Thanks everyone.
xklusivly4u
01-08-2008, 04:18 PM
bakerman
Posts: 65 - iTrader: (
Re: strings tension
The screws on the tuners don't affect string tension; they only change how easy it is to turn the tuner.
If you have equal strings & use the same tuning on the Jem & RG, they have the same string tension. (Technically, intonating for higher action increases tension since you need to lengthen the strings, but it's by a very small amount.) String length beyond the nut (if non-locking) and the trem's movement during bending can change the feel of bends. For example, a trem set up with 2 springs can seem slightly easier to push the strings a certain distance, yet take more force (and distance) to bend to a target pitch than with 3 identical springs.
Fret and neck size/shape,
scalloped fretboard
, fret/fretboard smoothness and string height are really the only other things that could effect how easy it is to fret & bend. None of those can change the string tension but might be the reason for a difference in feel.
bakerman
Find all posts by bakerman
01-08-2008, 05:20 PM
xklusivly4u
Re: strings tension
Both guitars have standard tuning and 0.009
gauge strings
. The differences are JEM has ebony, wizard neck, Lo Pro and RG is with rosewood, ultra neck and Edge Pro. Action on JEM is very low like 1.1 mm at 12 fret and RG is like 2.1 mm. I am not sure these are contribute to strings tension.
xklusivly4u
01-08-2008, 05:48 PM
AleTheNervo
Posts: 459 - iTrader: (
Re: strings tension
The difference can be determined by how stiff the tremolo springs are. Different springs and different configurations (three parallel, arrow, two parallel and one oblique) cause different responses to the strings feeling
AleTheNervo
Visit AleTheNervo's homepage!
Find all posts by AleTheNervo
01-08-2008, 06:01 PM
bakerman
Re: strings tension
I'd guess that you're just finding the Jem easier to play because of its lower action.
bakerman
01-08-2008, 08:58 PM
EL-CeeDee
Posts: 484 - iTrader: (
Re: strings tension
I notice the same issue, however...
The why is a mystery to me..
Physics state that the tension SHOULD be equal ( given equal circumstances )
The tremolo springs thing is a myth. The string will move easier, but take the same force to raise pitch a given amount.
a shorter scale length would make a difference, but comparing jem and rg ( or in my case, jpm ), this is equal ( if correctly intonated ).
My guess :
Smoothness of frets makes a difference in sliding the string over the fret. Resulting in a smoother, easier feel.
spring tightness makes a difference in the PERCEIVED feel, the effect on bends is psychological, as the only difference is a more gradual pressure increase on the string.
Neck profile allows for more or less leverage on the string, making it easier to excert the needed pressure to raise pitch a given amount.
Strange phenomenon
EL-CeeDee
Find all posts by EL-CeeDee
01-09-2008, 03:12 AM
bakerman
Re: strings tension
EL-CeeDee
While it's not exactly a difference in tension, I wouldn't call the effect psychological. With a bridge that sags during bending, you need to push the string further out of line to reach the same tension. It's a more gradual increase relative to distance, but a quicker increase relative to pitch. You need to arrive at a greater final force because the string has a greater restoring force.
Say you bend the high E 12th fret 1.5 steps, hold the bend, lock the bridge in place, release the bend and find the string is now at Eb. That means you had to reach the same force as tuning to Eb and bending 2 steps if this were a
fixed bridge
. That takes more force than bending 1.5 steps from E on a fixed bridge.
bakerman
01-09-2008, 06:34 AM
xklusivly4u
Re: strings tension
bakerman
It is not because of that entirely, I can feel the tensions even in lower fret where action difference is almost unnoticeable.
xklusivly4u
fixed bridge
gauge strings
guitar body
lock nut
neck bow
neck shape
rod adjustment
scalloped fretboard
string gauges
string tension
truss rod
truss rod adjustment
vintage trem
how to change strings on js 1200
what is the string tension for the extreme
uniform string tension is bad
what kind of strings does korn use
how to set the string tension on zr tremolo for 10 gauge strings
Strings for Whole Step Down (DGCFAd)
Zelman
01:54 PM
String tension, noob question
no1spretty
06:04 AM
FS: Strings, The Key!, Straps, etc.
jippy
02:54 PM
Which Strings?
beyblade
Gear and Equipment
03:43 PM
7 strings? - I'm running out of strings
1 1 Dragon 2 2 2
12:36 PM
11:40 PM
