Hey thanks guys for your input...
i might not've explained my situation fully though. the cliplocks I got aren't dimarzio.... they're from that strap company Levy's. these ones are a bit different in the sense that you just need to keep them under the existing strap pins, so no retrofit is required.
my problem is that the original ibanez strap pin won't stay in the guitar because the basswood is all stripped for some reason (it was a bit loose when i got it, but i had no idea it was almost completely stripped).
I guess, for now, i'll try the toothpick idea, but would i use wood glue to secure it, or should i just use the toothpick on its own. i'll try it and see what works.
thanks
-Pryde
