Old 05-18-2009, 07:45 AM
timerunsout  is offline
Posts: 21  -  iTrader: (0)
Stuck trem arm
Does anyone know any methods of removing a broken piece of whammy bar from an Edge tremolo? It's stuck in there pretty good
Also what does the tiny screw on the back of the tremolo actually do? It's under the hole where you stick in the arm
Old 05-18-2009, 09:03 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Re: Stuck trem arm
Do you mean the screw that holds the spring that keeps the bar in?
The screw on the left.
You could remove this screw and the spring and see if the broken bit falls out now, if not you may be able to poke something in the hole and get the piece out that way...
Take it easy though!
Jim
Old 05-19-2009, 08:08 AM
Re: Stuck trem arm
Hey it worked! Thanks a lot
By the way how does the screw and the 'spring' keep the trem bar in? I tried adjusting it whilst the bar was in one piece but it didn't seem to do anything. And the spring on mine looks a lot like a piece of wire meant to act like a washer or something
Old 05-19-2009, 09:21 AM
Images: 6
Re: Stuck trem arm
The spring catches in the notched end of the trem arm, it doesn't adjust how easily the arm swings, just stops it falling out. To adjust tension you have (or should have) 2 nylon bushes (little C shaped bits of plastic) that press against the sides of the arm holder. If the arm is slack you need to replace these or possibly put some cellophane underneath them.
Jim
arm tremolo rg550 edge
I stuck it to the man Smitty Off-topic / Miscellaneous 23 04-06-2008 10:32 PM
Stuck in a rut! Rekuss Guitar Lessons & Music Theory 6 08-08-2007 11:40 AM
trem post is stuck oYx Tech: Setup, Repairs and Mods 6 06-01-2006 11:18 PM
Broken!! (trem arm stuck in holder) elwood hitch Tech: Setup, Repairs and Mods 10 03-22-2005 08:50 AM
stuck bar pulled trem right out jim777 Tech: Setup, Repairs and Mods 5 01-27-2004 01:28 AM
