Sustainer Light always on!? - Jemsite
Old 08-17-2008, 03:21 PM
Ryan350DX  is offline
Posts: 179  -  iTrader: (0)
I'm going through batteries like theres no tomorrow, my chipboard has a little red light on it, that always stays on!. I unplug my guitar and sometimes I will forget the sustainer is on when I put it away, but when I first got my sustainer installed I couldnt use the sustainer while the guitar was unplugged. Any suggestions?
Old 08-17-2008, 03:22 PM
GuitarGuru  is offline
Posts: 860  -  iTrader: (2)
Reviews: 3
Re: Sustainer Light always on!?
I've repaired this problem before. The wiring has short. This causes a drain on the system.
Old 08-17-2008, 07:36 PM
LonePhantom  is offline
Posts: 8,995  -  iTrader: (11)
Reviews: 120
Didn't you pay someone to install it? It sounds like they didn't install something properly, maybe you should take it back and get them to fix it.
Old 08-18-2008, 02:31 PM
How did you go about fixing it?
Thanks
Old 08-18-2008, 03:24 PM
Reviews: 3
Try replacing the battery clip. If that doesn't work, have fun replacing the wiring.
Rick
Old 08-19-2008, 03:10 PM
Rick
I'll take the battery out when I'm done playing it
F changing the wiring.
Old 08-19-2008, 07:59 PM
Reviews: 3
If you want to send it to me, I can rewire it with all new wires and replace the clip for $65.00.
Old 08-20-2008, 02:50 PM
No thanks man i've already dumped over 500 dollars in it in the past month..
Sustainer $243.13 (thats taxes and shipping)
Installation $264.04 (which is total BS)
2 pack of Duracell 9v $7.99
Total ----- $515.16
Heres the invoice
Old 08-20-2008, 06:19 PM
Reviews: 3
Did they give you a Towel and some Jelly?
Old 08-20-2008, 07:56 PM
Reviews: 120
Again, why have you not gone back and got them to fix it up under warranty? If they haven't done it properly they are obligated to fix it for you.......
Old 08-20-2008, 07:59 PM
CosmicDebris  is offline
Posts: 3,980  -  iTrader: (7)
It is probally to late for him to take it back now. He has modded their work and they will say he messed with it which he has and will refuse to fix it. Sorry man for the trouble your having with it but the ****ty job they did and the money you paid someones ass would have been chewed a bit.
Old 08-21-2008, 03:05 PM
I was scared to take it back and have him route more and take everything apart he probably woulda ****ed it up even worse, I took off his **** pickguard and put the old one back on, Im looking around stores to find an ultra cheap single coil with a flat cover on it to shimmy neck to the sustainer, but first I need to route a little room for the sustainer to sit flush with the neck (because it is longer than a regular single coil). Once thats done I gotta figure out where that mysterious white wire goes.
Heres some pics: http://www.jemsite.com/forums/f35/wh...ics-80379.html
Old 08-23-2008, 06:29 PM
6stringer  is offline
Posts: 108  -  iTrader: (0)
Old 08-24-2008, 04:10 AM
Reviews: 3
The white heads on the board are adjustable. Use a small screwdriver and download the manual from Fernandes. If you take the battery and jiggle it, does the light go on or off?
Old 08-24-2008, 12:57 PM
The white heads are called Trim Pots, The last time I messed with those I had to get a replacement chipboard. They do nothing for the battery, they adjust gain, balance. I can mess with the battery clip, but Im thinking its got something to do with the output jack, because when I first got the guitar back I had a really hard time plugging the cable in, now it goes in easier, I think the output jack thinks there is still a cable in there cause its to tight.
eye , hate , putting , tags , wtf
Rumble stage light? Myst and rain Gear and Equipment 5 07-11-2007 08:07 PM
New song: Light Out Of Darkness rya Multimedia: Music, Pictures & Sounds 4 02-14-2007 10:09 PM
My eyes have been opened...I have seen the light... lyconxero Other 6-string Guitars (non-Ibanez brand) 26 05-09-2006 03:09 PM
My Jems in Black light...... Mrcoincoin JEM and Universe Guitars 15 08-27-2002 04:11 PM
Powered by
