Old 11-16-2006, 07:43 PM
hyperlite_rider  is offline
Posts: 8  -  iTrader: (0)
sustainer position?
would it be possible to put a sc sustainer driver in the place of a middle pickup (liek in a hsh config.)
btw im working on building a custom jem-style guitar and I have no idea where do go.
Id like to do a lng setup but imo thats kinda butchering the "prestige" of the idea behind the lng (that being the limited edition) and even though it would be top quality with mostly all the same parts (small differences like I preffer edgepro to lopro) It just seems like it would be corny, like im trying to rip it off, Is that crazy or do you get it?
I also like the swirls but they are really expensive (worth it I know) but I think they are out of my pricerange (and nobody close by does them)
the 7vwh is my last pick but Im probably gonna go with it (problem is it just screams EVO)
I know you all hate ibanez copies but whats the problem if I want to get a quality built body and neck, and load it up with excelent parts, almost the same as stock, just in some cases different (like paf's instead of evo's) and never pass it off as a true ibanez
the only problem is that I can forsee is resale, it will have no resale value at all
Old 11-17-2006, 01:21 AM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
Re: sustainer position?
im thinking it would work but not as effective as it can in the neck. and maybe not in the infinite sustain the higher the string. maybe it depends how much sting tension there is?? im making a sustainer topic, maybe that will help you out too
Old 11-17-2006, 01:42 AM
Koss  is offline
Posts: 1,127  -  iTrader: (2)
Won't work. It has to be in the neck position. Both Fernandez and Sustainiac say so. One reason is because of string tension, but I think there are a couple other reasons...
I believe the question is asked in both companies FAQ sections, and they go a bit more in depth.
Old 11-17-2006, 02:55 PM
JackButlerGOT  is offline
Posts: 351  -  iTrader: (0)
True for any on board style sustainor. I've got guitars both equipped with the Sustainiac and the Floyd Rose Sustainor and due to tensions and placement of harmonic nodes on the strings themselves, it'll have to go in the neck position. It also has to be square with the neck itself. I had enquired once about having one put in a 27 fret guitar I have with a slanted fingerboard and that's a "no no" as well.
custom jem, floyd rose, fret guitar, neck position, string tension
7 string sustainer r00key Pickups & wiring 5 11-12-2008 10:27 AM
Help needed - Sustainer problem Mattww Pickups & wiring 2 03-01-2006 02:54 PM
Ibanez RG 550/560 hybrid with sustainer. UK Jammy Classified Ads: Guitars and Gear 2 06-24-2005 02:06 PM
Fernandes sustainer strat - ...arrived a couple weeks ago gkelm Other 6-string Guitars (non-Ibanez brand) 1 08-17-2001 11:02 PM
