Old 03-27-2007, 07:52 PM
Codyyy  is offline
Posts: 68  -  iTrader: (0)
Swap Jackson Trem for Edge LoPro?
Hey I'm Cody. I'm new here, and sadly, I do not own any Ibanez guitars. However, if I had the means I would not hesitate. At any rate, I have a Jackson DK2M. Right now, it has a Jackson JT580 Low Profile Tremolo in it. I tried swapping it out for an OFR (much before I considered any Ibanez trem), but the routing is too deep for it so I could always pull the OFR back way too much and deaden the strings. The Jackson is routed for a low profile trem. So my choices are either, a Floyd Rose Pro, or some sort of Low Profile Edge. From what I've seen most if not all of you favor Edge over all Floyd, but tell me. Are the OFR (or FR Pro) and any version of the Edge directly swappable? If so, which model do you reccommend? Thanks for all help.
Old 03-27-2007, 08:02 PM
Gurj  is offline
Posts: 1,912  -  iTrader: (19)
Images: 6
Re: Swap Jackson Trem for Edge LoPro?
I had a Lo-pro fitted on my soloist and although the trem posts holes didn't need redrilling, ALOT of routing would have had to be done for the trem to fitted snuggly. But by the sounds of it that isn't that much of an issue with your DK2M. So either an Edge or Lo-Pro trem may just work fine, although you may have to redrill some holes for the trem posts.
floyd rose, floyd rose pro, ibanez guitars, ibanez trem
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
Can't get edge trem in adjustment - always too high, too low bduersch Tech: Setup, Repairs and Mods 4 11-19-2001 12:37 AM
LoPro Trem Bar - Assembly keeps coming loose jippy Tech: Setup, Repairs and Mods 17 11-07-2001 11:06 PM
Lo-Pro Edge Trem Level? - Does the trem need to be level wit Dean Southcombe Tech: Setup, Repairs and Mods 5 06-11-2001 10:09 PM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions - GO HERE FIRST 2 01-01-2001 09:24 PM
