Tech: Setup, Repairs and Mods
Swapped LoTRSII for an OFR (with pics)
Page 1 of 3
03-04-2005, 08:49 PM
pete944
Posts: 48 - iTrader: (
I got my Original Floyd today and replaced the LoTRSII. It is a direct swap. Even the stud inserts are the same size. I installed the Floyd inserts and they have a lot less slop than the LoTRS pieces.
Before pic:
Removing the old stud inserts:
New studs installed:
Test fitting the OFR:
08:54 PM
pete944
Find all posts by pete944
03-04-2005, 08:53 PM
parker_fly
Posts: 398 - iTrader: (
Re: Swapped LoTRSII for an OFR (with pics)
nice man! Thanks for the pics too..
parker_fly
Find all posts by parker_fly
03-04-2005, 08:55 PM
pete944
Too many pics for one post. Hang on.
pete944
03-04-2005, 09:00 PM
pete944
I set the saddles close to the positions on the LoTRS so it would be close for intonation:
Then I swapped the strings over to the OFR:
Installed:
The gap between the OFR and the recess is a little wider on the left side but I can live with it.
The finished product:
The guitar stays perfectly in tune now and sounds and sustains much, much better.
This is an easy job and anyone with a LoTRSII should do it.
pete944
03-04-2005, 09:17 PM
pete944
Two things to note:
1. The string
retainer bar
that came with the Floyd is wider than the Ibanez part. I put it on but it was too wide and the ends stuck out past the sides of the headstock. You can see it in the last pic.
2. The spring block is longer than the LoTRS block. When I put the back cover on the block and springs would hit it on pull ups. This is probably only an issue on the 'S' models since the body is very thin. I'll get out the Dremel tomorrow and cut a clearance hole in the cover tomorrow. I could just leave the cover off but I'm wierd that way.
I swapped nuts too since the original is a very worn cosmo finish but the OFR nut is too tall. I'll grind about 3/32" off of the bottom of it and swap it later.
I did take a little Comet to the
pickup rings
when I swapped pickups and got the ratty Cosmo finish off. The came out a nice, shiny chrome.
The whole job only took about 45 minutes. Even if you've never done this before, I can't see it taking more than an hour and a half.
09:29 PM
pete944
03-05-2005, 12:57 AM
Tubarão Guitars
Posts: 3,965 - iTrader: (
Wonderful
If i get something with LO TRS i gonna do the same, no doubt!
What about flutter now?
Tubarão.
Tubarão Guitars
Visit Tubarão Guitars's homepage!
Find all posts by Tubarão Guitars
03-05-2005, 01:15 AM
toshiro
Posts: 1,812 - iTrader: (
pete944
I did take a little Comet to the pickup rings when I swapped pickups and got the ratty Cosmo finish off. The came out a nice, shiny chrome.
Wonder if this would work on all
Cosmo hardware
. The LoPro in my S540 would look better with the semi-clear black layer removed, since it's worn off a lot already.
You used the powder Comet? Soaked the parts in it, or?
Since I'm dyeing the fretboard on that particular guitar over the weekend, I could give this a shot too.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
03-05-2005, 03:09 AM
pete944
Flutter is great. Harmonics are better too.
I used a damp rag and Comet to scrub off the remains of the Cosmo finish on the pickup rings. A buffing wheel on a Dremel would be faster but I thought of it after I finished the rings. Doh!
09:48 AM
pete944
03-05-2005, 04:06 AM
fettouhi
Posts: 9,937 - iTrader: (
Maybe I should this also to my Jem Jr.! Anyway great pics, have fun with it!
Regards
André
fettouhi
Find all posts by fettouhi
03-05-2005, 05:21 AM
toshiro
pete944
I used a damp rag and Comet to scrub off the reamins of the Cosmo finish on the pickup rings. A buffing wheel on a Dremel would be faster but I thought of it after I finished the rings. Doh!
Cool, I'll give it a shot, using the most worn saddle as a demo, since it's mostly chrome already.
Thanks for the tip.
toshiro
03-05-2005, 10:20 AM
Zeppel
Posts: 80 - iTrader: (
Since i've never seen a stud out of the guitar live... how do you insert the new ones? They're knurled or something? You hammer then in? Thump thump that's it?
Zeppel
Visit Zeppel's homepage!
Find all posts by Zeppel
03-05-2005, 11:10 AM
pete944
Zeppel
Yep, just hammer them in. Use a block of wood or something between the hammer and the insert so you don't screw it up. The insert is brass and brass is fairly soft. I used an old screwdriver. I put the handle end on the insert and hammered it right in. The Floyd inserts are knurled and a tight fit, which is good.
12:24 PM
pete944
03-07-2005, 07:20 PM
Ironjose
Posts: 1,060 - iTrader: (
Hmmm... nice job, my intention is the same change my lt1 for a
floyd rose pro
, in my GRG 370, my only question is the nut??? which is the standard size ???
Ironjose
Find all posts by Ironjose
03-07-2005, 07:38 PM
pete944
Not sure on your guitar but mine is an R3.
pete944
03-07-2005, 08:30 PM
Ironjose
where did you say that you bought it ???
i intent to buy it from ed roman.
i`m guessing that R3 is the size, how did you know the size of your guitar`s nut?
Ironjose
Page 1 of 3
cosmo hardware
floyd rose
floyd rose pro
killer guitar
lock nut
low trs
maple neck
pickup ring
pickup rings
pro edge
retainer bar
trs trems
ibanez rg 550 ? pics
DNA & UVMC family pics ...well sort of
rvj
06:02 AM
NAMM 2002 - Pics Up
03-05-2002
10:16 PM
NAMM pics !!
edo
04:08 AM
04:11 AM
