Old 09-24-2001, 05:31 PM
djrjems  is online
Posts: 190  -  iTrader: (3)
Swapping necks, will a Jem neck fit an RG? - Can I put a Jem
I'm pretty sure this will work, but I want to double check before I close this deal. *I've got a couple early 90s RG570s with the original neck joint. *I've got an opportunity to buy a Jem7RB neck for a pretty good deal. *The Jem7RBs have the original neck joint as well. *
I know the body shape (at the joint) is different between Jems and RGs with original neck joints, but is that the only difference? *Are there any concerns with this being a "no-brainer" fit on an RG570? *Thanks guys!
Old 09-24-2001, 06:42 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
It should be a direct fit but you might need to shim for setup... glen
Old 09-24-2001, 10:25 PM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
I wouldn't see any problem and as Glen said the only thing you might need to do is add a neck shim.....
Old 09-24-2001, 10:27 PM
djrjems  is online
That's what I thought *
Thanks a bunch guys *:biggrin:
(Edited by djrjems at 9:27 pm on Sep. 24, 2001)
Old 09-26-2001, 01:36 PM
cerealk  is offline
Posts: 2,428  -  iTrader: (5)
my BFP neck fit my RG 750 body no problem
(may use a shim on it though)
Old 09-29-2001, 02:14 AM
djrjems  is online
The Jem neck fit the 570 perfectly! *I had to shim the neck side with a couple business cards, but now I'm rockin' *:biggrin:
Thanks again guys!
bfp neck, body shape, jem neck, neck joint, neck joints, neck shim
