Old 10-08-2008, 04:05 PM
2TS  is offline
Posts: 27  -  iTrader: (0)
Question
Swirling a pickguard.. is it possible???
hi... i want to swirl a black pickguard from a Ibanez RG with black+white+red colors...
i know that oil paints will not stick to plastic, i'm wondering about those plastic paints on spray cans (spray some on a little can and then drop on water) or to prime the pickguard and use some puliurethane paint... but i reallt don't know how these 2 paints will float or work nice on "boraxed" water???
any ideia???
anybody already did that???
Old 10-08-2008, 05:58 PM
Foulacy  is offline
Posts: 354  -  iTrader: (0)
Re: Swirling a pickguard.. is it possible???
you can just order one from pickguard paradise if you want
Old 10-08-2008, 08:06 PM
2TS  is offline
Cool
that's the easy (dumb) way...
i'm a DIY guy
Old 10-08-2008, 08:39 PM
Lordiesel  is offline
Posts: 448  -  iTrader: (1)
Images: 1
when I tried spray paint it dried straight away and skinned on the water. Prime the pickguard maybe?
Old 10-08-2008, 10:35 PM
2TS  is offline
Lightbulb
ok, spray directly on the water i think will not work... i'm thinking of spray a lot on a little cup so i can get some of the paint in liquid form...
yes... i can prime and use a good paint... i think most of swirls are done with oil paints... if i prime it i have to go for puliuretane or enamel paints, don't know about oil paints and prime
i think i'll go for prime and enamel because i think puliuretane will no spread on water and it's a expensive paint...
Old 10-08-2008, 10:50 PM
Images: 1
oil paints and primer work... thats what I've used before. Don't know if the spray can idea would work. Worth a shot... you can get some really nice fluorescents in spray cans.
Old 10-08-2008, 11:09 PM
2TS  is offline
Talking
i'm a little step to try a special plastic paint i think i'ts based on enamel and acrilic and don't need prime... but it's very expensive... i think it will not work on water but would the best shot to do a pickguard if not swirled...
maybe i'll buy one can to try it.. if it not work i'll have to prime and go for enamel or oil...
i'll post some result pics later... thanks!!!
Old 10-09-2008, 07:48 PM
Bowie  is offline
Posts: 104  -  iTrader: (2)
Just scuff the pick guard w/ some 600 grit so that there is a surface for the paint to stick to.
Old 11-14-2008, 02:02 AM
2TS  is offline
Wink
here it goes...
i didn't sand the pickguard but i bought some vinilic paint used on silk-screen painting... its perfect and glue right on plastic... perfect for pickguard and very easy to do...
i use borax swirl and then i had the ideia to make little drops of white color over it, like sprayed... it already need to be finished with 3 layers of vinilic clear paint...
http://img48.imageshack.us/img48/2594/ideiazb3.jpg
http://img223.imageshack.us/img223/3...dofornoug3.jpg
here without the masking and the 45° scratched out... the custom paiting will be just on the top of the pickguard... i could have used some 3ply with white... but now it's late...
http://img135.imageshack.us/img135/8541/quasegr6.jpg
That's it...
Old 11-14-2008, 02:21 AM
GilkyBear  is offline
Posts: 4,110  -  iTrader: (16)
Wow man, I wasn't expecting it to come out that nice, it's awesome! Great job
Old 11-14-2008, 07:36 PM
TKO Ken  is offline
Posts: 157  -  iTrader: (0)
Hello all, I'm a newbie and here goes my first post. Let's see if I can not sound like a fool *grin*
As far as using spray cans to swirl? You could try holding the can upside down, pushing the nozzle and letting all the gass out, than poke a small hole in the can near the top and just pour the paint out. It might work.
2TS, that came out cool!! I hope the paint won't be worn off from picking. I'm gonna have to give that a try some time soon.
Regards, Ken
Old 11-27-2008, 08:01 PM
hangingmonkey  is online
Posts: 126  -  iTrader: (0)
Images: 15
Nice swirl.
Did you spray the white or individually drop blobs of white onto the pick guard?
Old 01-18-2009, 02:43 PM
2TS  is offline
Talking
It's finished and mounted together...
It's custom RG 350. I got it in all separated parts (including neck and body) from e-baay and some stores and everything came to my house very slowly (i live in brazil)... took maybe half a year to swirl the pickguard and finish everything and do the electronics and setup... but i'm very amazed with the result... the sound is incredible and the visual is nice...
Body from a 350DX
Neck from a 350 SP1
pickguard custom made (without middle pickup hole) by Redzline and swirled by myself with vinilic paint
Dimarzio Fred + Air Norton
Gotoh Floyd Bridge (customized by myself to fit the EDGE III cavity)
Nice mother of pearl top knobs
Super switch doing 5 sounds from the two humbuckers...
http://img179.imageshack.us/img179/7804/prontatz8.jpg
http://img179.imageshack.us/img179/5051/pickze3.jpg
http://img179.imageshack.us/img179/1374/headvs5.jpg
http://img359.imageshack.us/img359/228/tampako5.jpg
Thanks to the ones that helped!!!
Old 01-18-2009, 05:13 PM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Just to add... Swirling pickguards is no problem. My Herc Fede swirl is swirled with the pickguard attached to the body. Just don't ask me how.
Old 01-18-2009, 05:45 PM
Jem7RB MK  is offline
Posts: 2,341  -  iTrader: (20)
Give m8, give, and i know how it's done, it's mentioned a bit further up in this thread.
Always loved that axe dude, as you well know
Rob
pickguard, rg 350dx, swirl
Swirling about swirls HDS Vendors, Auction & Reseller Talk 25 10-27-2008 12:39 AM
what exactly does borax do when swirling? Dragon Slayer J Tech: Setup, Repairs and Mods 11 04-30-2007 11:43 AM
Swirling :) fettouhi Tech: Setup, Repairs and Mods 4 03-21-2007 07:17 AM
Swirling of the Gods... A how to ????? stratosqueeg JEM and Universe Guitars 22 11-09-2005 01:27 PM
Swirling an RG? Swirly Tech: Setup, Repairs and Mods 3 04-04-2003 01:51 PM
