Old 02-16-2004, 05:03 PM
Asgaroth  is offline
Posts: 32  -  iTrader: (0)
the tremolo angle setup - need help (photos included)
Hi All,
Need help of seting the tremolo angle
I have tighten the screw almoost till the end - but it does not help.
http://www.nextd.net/ibanez/ibanez.htm - here is 4 picture of my bridge and what I'm trying to do.
Please help with advise.
Thank you
P.S. Guitar Ibanez 570RG 2000y
Asgaroth
Old 02-16-2004, 05:07 PM
Rich  is offline
Posts: 19,356  -  iTrader: (21)
The claw still has a little more to go
You've either got 10's on there or your springs are getting weak.
Old 02-16-2004, 06:19 PM
Asgaroth  is offline
strings are 9th though wish to change to 10th.
I have tried springs from my friend Ibanez = not helping ;(
and even if I tighten the screw till the end it is not solving the problem
so what should I do? may be I'm missing somthing here
Old 02-16-2004, 06:22 PM
woodros  is offline
Posts: 303  -  iTrader: (0)
i like your flower
Old 02-16-2004, 07:58 PM
Rich  is offline
The strings are either actually 10's [wouldn't be the first time 10's got labeled 9's], or, you are tuned too high.
Old 02-16-2004, 08:04 PM
Asgaroth  is offline
well I've tuned normaly E
and they are really 9
may something wronh with factory bridge set-up? I'm the original owner
Old 02-16-2004, 08:08 PM
Rich  is offline
Was it way out of whack and you're trying to get it back to normal? If so the last section here covers it.
http://www.ibanezrules.com/tech/setup/tuning.htm
Old 02-16-2004, 08:21 PM
Asgaroth  is offline
ok, ty, I will take a look
Old 02-16-2004, 08:46 PM
bachle7  is offline
Posts: 306  -  iTrader: (0)
What Rich describes on his webpage has happened to me a few times. The strings feel really tight and the trem is jacked up too high. I loosen all the strings and start over. (It seems to defy physics!)
Old 02-16-2004, 08:58 PM
Rich  is offline
Everybody with a floating system has experienced this before. In a way it does seem to defy physics, springs have a physics all their own I think. Usually this is described as "I just changed my strings and I can't get my trem down!", much easier to spot the source of the problem that way
Old 02-17-2004, 03:41 AM
Fry  is offline
Posts: 259  -  iTrader: (0)
That happened to me on my first trem guitar, and i was about to jump out of my building, then I figured it out after about 2 hours of messing around with it. (and stripping the crap out of the claw screws)
Old 02-17-2004, 08:40 AM
Asgaroth  is offline
Well well well
The same happened to me I've spen good 7 hours jumping around. Now It seems a correct setup
Thank you All for help
Rich, your article helped me a lot thank you
Old 02-17-2004, 11:37 AM
MicJustMic  is offline
Posts: 931  -  iTrader: (0)
I have yet to have this happen to me, and I’ve tuned/set up quite a few FR equipped guitars.
I just don’t understand the physics of it, when the string is at pitch it exerts so much force, no more no less no matter how you tune it, or am I wrong about that?
If a D’Addario .042 is tuned to E it exerts 14 pounds of pull, correct? How can tuning it all the way up to pitch before the others, then tuning the A to pitch, and so on, cause the bridge to pull up out of the body?
I don’t know if I’m just not understanding or what, but I’ve never had this happen, and yes I have tuned FR trems in this manner on occasion. Not so much with the deep routs on RGs and Jems, since if you have the strings all slack the bridge is so far in the body the strings are against the fretboard, making this impossible, but with other models/brands where the rout isn’t quite so deep.
I’ve even tried to make this happen, to try to figure out the physics involved and couldn’t do it . . . am I just dumb? :-)
Mic
Old 02-17-2004, 11:52 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
it all depends on what springs you're using, how long they are and how hard they pull.
it happened to me many times. i usually slacken the strings and start over, and if this doesnt work, i'll set the springs in arrow configuration. it works.
Old 02-17-2004, 02:22 PM
Rich  is offline
I'm not saying I completely understand the physics behind it, I believe it has much to do with spring memory and how not to break that memory. I just always detune to pitch from a blocked position when changing string to totally avoid it ever happening
claw screws, equipped guitar, trem guitar, tremolo angle, truss rod
